here's an other catastrophic compiler error report (version 14.0.1); maybe it helps to improve ifort!
The error is caused by invoking an elemental binary operator (as '==') on polymorphic arrays of abstract declared type.
[fortran]
module m
implicit none
! abstract parent type with elemental equality operation
type, abstract :: abstr_parent_type
contains
procedure(is_equal_interf), deferred :: is_equal
generic :: operator(==) => is_equal
end type
abstract interface
elemental function is_equal_interf(this, other)
import abstr_parent_type
class(abstr_parent_type), intent(in) :: this, other
logical :: is_equal_interf
end function
end interface
! extended type overrides abstract equality operation
type, extends(abstr_parent_type) :: child_type
integer :: field = 0
contains
procedure :: is_equal => child_type_is_equal
end type
contains
elemental function child_type_is_equal(this, other)
class(child_type), intent(in) :: this
class(abstr_parent_type), intent(in) :: other
logical :: child_type_is_equal
! any comparision code
child_type_is_equal = .true.
end function
end module
program t
use m
implicit none
! must be array(!) of abstract(!) parent in order to crash
class(abstr_parent_type), allocatable, dimension(:) :: arr1, arr2
! run elementwise comparisions on child_types
allocate(child_type :: arr1(1), arr2(1))
! variant 1: catastrophic error
if (all(arr1 == arr2)) then ! CRASH
print *, 'arrays are equal'
end if
! variant 2: no error (legal?)
if (all(arr1%is_equal(arr2))) then
print *, 'arrays are equal' ! works
end if
end program
[/fortran]
COMPILE LINE:
ifort elementwise_type_bound.f90
OUTPUT:
catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for elementwise_type_bound.f90 (code 1)
WORKAROUND QUESTION:
Is variant 2 (with the elemental type bound function invocation directly on the array) a standard conforming F2003 alternative?
Ferdinand
Thanks - I will send this off to the developers. There's nothing wrong with calling the function directly - indeed, the use of the operator ought to translate to a call to the function.
It's just that I never called a type bound function from an arrayvariable before, e.g. 'arr%func()' instead of 'array(index)%func()' and I am glad to hear that this is legal syntax. Thank you!
With an elemental function, the syntax you chose passes an array which is fine.
Issue ID is DPD200249693.
While writing some code with that nice 'elemental function on array invokation' syntax I run into a probably related issue (catastrophic compiler abort on type bound elemental generic, when called from array) which I managed to reduce to the following program:
[fortran]
module m
implicit none
! type bound elemental generic
type :: derived_type
contains
! generic interface for type bound elemental (pass or nopass)
procedure, nopass :: do_specific
generic :: do_generic => do_specific
end type
contains
elemental subroutine do_specific()
end subroutine
end module
program p
use m
implicit none
! must be array(!) of derived types in order to crash
type(derived_type), dimension(1) :: my_derived
call my_derived%do_specific() ! works
call my_derived%do_generic() ! CRASH
end program
[/fortran]
In the hope posting those issues here is helpful and with best regards,
Ferdinand
Yes, your posting these is very helpful! Thanks.
