end-of-file during read error
oforion
Hi all, I have just begun to try my hand at parallel programming and am using mpich. however with my first code I cannot seem to run it because I keep on recieving the following error with its outputs;
enter the number of processors available
forrtl: severe (24): end-of-file during read, unit -4, file stdin
Image PC Routine Line Source
phase 080D2BAC Unknown Unknown Unknown
phase 080D26A4 Unknown Unknown Unknown
phase 080AB601 Unknown Unknown Unknown
phase 0808DA78 Unknown Unknown Unknown
phase 0808DF1B Unknown Unknown Unknown
phase 0809A772 Unknown Unknown Unknown
phase 0804AB27 Unknown Unknown Unknown
phase 0804AA48 Unknown Unknown Unknown
Unknown B7E57E80 Unknown Unknown Unknown
phase 0804A901 Unknown Unknown Unknown
phase 080D26A4 Unk nown Unknown Unknown
which repeats for a bit more. whats even more odd is that after these error messages i am still allowed to enter the input however the program doesn't run accordingly. the read statement requires input from a user and is as follows;
print*, 'enter the number of processors available'
read *, procrqd
print*, 'enter the nucleation frequency, i.e. lambda (ensure dimensionless)'
read *, lambda
print*, 'enter maximum simulation time and linear sample size'
read*, max_time,system_size
print*, 'enter dt'
read*, dt
print*, 'enter dx'
read*, dx
print*, 'enter nucleation radius'
read*, Rad
print*, 'enter how often to print files'
read*, print_freq
when I comment out the first read statement is jus gives me the same error with the second statement.
anyone have anythoughts and or solutions.
thanks
nana
Ron_Green
Nana,
It could be many things - most likely though you are not restricting your code path for the read to the rank 0 process.
In a parallel program it is traditional for only process rank 0 to receive input from the user. Do you have something like:
integer : rank, mpierr, foo
call MPI_Comm_rank(MPI_COMM_WORLD,rank,mpierr)
if ( rank == 0 ) then
print*, "enter foo"
read*, foo
end if
call MPI_Broadcast( foo, 1, MPI_INTEGER, 0, MPI_COMM_WORLD)
