error 174:segmentation fault
anamika_shrivastava_
hi, i am using intel compiler version 9.0.IN WPS compilation i am getting error174:segmentation fault, for remove it i have check stack size and done itunlimited. but still i am getting same problem how i can do succefull running of WPS , plz tell me the right way.
Kevin_D_Intel
It is unclear from the information provided if the fault relates to a compiler defect or the compiler options used.
9.0 is an older unsupported release. As a first step you should consider upgrading to at least our latest 11.0 release. If your support subscription is still valid, the latest 11.0 update is available from our Intel Registration Center here.
If by WPS, that means the WPS related to WRF, then the following Knowledge Base article on building WRF with Intel Compilers may help:
http://software.intel.com/en-us/articles/performance-tools-for-software-developers-building-wrf-with-the-intel-compilers/
