I have following error while compliing codes using ifort.
error #5082: Syntax error, found ',' when expecting one of: => = . [ % (
icalir(iIR), ipw, enev(iene)
xyx.f90(285): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: ] ,
compilation aborted for xyz.f90 (code 1)
make: *** [xyz] Error 1
the part of code is reproduced below.
ALLOCATE (icalir(nirs))
CALL INT_VOL(icalir(iir),np,nstab,ek)
!**** Create file for Chase int.
do i=1,np
write(91,'(4e19.10)') (km(i,j),j=1,np)
end do
!**** Create file for poly
lwrite=17
ipw=ioffl(lwrite+1,icalir(iir))-1
write (90+iene, '(2i10, e16.8)')
$ icalir(iir), ipw, enev(iene)
do i = 1, ipw
write (90+iene, '(e20.10, 3e19.10)') (km(j, i),j = 1, ipw)
end do
how to overcome. what should i write in my codes
ab
The source file being compiled is named xyx.f90
File types of .f90 are free form.
The line bolded in your pasted code, (please use {...} button to paste sample code)
is not a continuation line in free form. It may have been a continuation line in fixed form, when the source file was named xyx.f
write (90+iene, '(2i10, e16.8)') & ! The ampersand indicates line to be continued
icalir(iir), ipw, enev(iene) ! first non-comment line is continuation line
See the IVF documentation to see rules for continuing long character literals.
Jim Dempsey
