I had a working code (sources files + header file+ included files in .f) which was working fine. I had installed following system in my window10 Enterprise, then initially I got the error on license not found ( however license was found at the location mentioned in environment variable). I thought reinstalling should solve the issue. although it solve the license issues, but got a new bunch of errors in the working code which I could not figure out the reason. A help would be appreciated on the same.
System info:
Microsoft Visual Studio 2010
Version 10.0.30319.1 RTMRel
Microsoft .NET Framework
Version 4.7.02053 RTMRel
Installed Version: IDE Standard
Microsoft Visual Web Developer 2010 01011-532-2002361-70606
Intel(R) Visual Fortran Package ID: w_fcompxe_2013_sp1.6.241
Intel(R) Visual Fortran Composer XE 2013 SP1 Update 6 Integration for Microsoft Visual Studio* 2010, 14.0.0100.2010, Copyright (C) 2002-2014 Intel Corporation
window 10 enterprise x64
Error details:
Error 49 error #6200: A colon (:) is not valid in this context. .\file1.f 6
Error 51 error #6200: A colon (:) is not valid in this context. .\file1.f 7
Error 53 error #6200: A colon (:) is not valid in this context. .\file1.f 8
Error 19 error #6303: The assignment operation or the binary expression operation is invalid for the data types of the two operands. .\file2.f 662
Error 36 error #6341: A logical data type is required in this context. .\file2.f 697
Error 8 error #6341: A logical data type is required in this context. [var1] .\file2.f 626
Error 61 error #6341: A logical data type is required in this context. [var1] .\file2.f 751
Error 57 error #6341: A logical data type is required in this context. [var2] .\file1.f 21
Error 6 error #6341: A logical data type is required in this context. [var3] .\file2.f 572
Error 43 error #6341: A logical data type is required in this context. [var3] .\file2.f 733
Error 9 error #6358: Constants and expressions are invalid in read-only I/O lists. [var4] .\file2.f 627
Error 12 error #6358: Constants and expressions are invalid in read-only I/O lists. [var4] .\file2.f 630
Error 17 error #6358: Constants and expressions are invalid in read-only I/O lists. [var5] .\file2.f 657
Error 15 error #6358: Constants and expressions are invalid in read-only I/O lists. [var6] .\file2.f 653
Error 37 error #6358: Constants and expressions are invalid in read-only I/O lists. [var6] .\file2.f 714
Error 44 error #6358: Constants and expressions are invalid in read-only I/O lists. [var7] .\file2.f 734
Error 41 error #6358: Constants and expressions are invalid in read-only I/O lists. [var8] .\file2.f 724
Error 16 error #6358: Constants and expressions are invalid in read-only I/O lists. [Rvar4] .\file2.f 654
Error 38 error #6358: Constants and expressions are invalid in read-only I/O lists. [Rvar4] .\file2.f 714
Error 47 error #6358: Constants and expressions are invalid in read-only I/O lists. [var9] .\file2.f 741
Error 39 error #6358: Constants and expressions are invalid in read-only I/O lists. [ROE] .\file2.f 715
Error 33 error #6385: The highest data type rank permitted is INTEGER(KIND=8). .\file2.f 697
Error 35 error #6385: The highest data type rank permitted is INTEGER(KIND=8). .\file2.f 697
Error 7 error #6385: The highest data type rank permitted is INTEGER(KIND=8). [var1] .\file2.f 626
Error 60 error #6385: The highest data type rank permitted is INTEGER(KIND=8). [var1] .\file2.f 751
Error 34 error #6385: The highest data type rank permitted is INTEGER(KIND=8). [var5] .\file2.f 697
Error 32 error #6385: The highest data type rank permitted is INTEGER(KIND=8). [var10] .\file2.f 697
Error 5 error #6385: The highest data type rank permitted is INTEGER(KIND=8). [var3] .\file2.f 572
Error 42 error #6385: The highest data type rank permitted is INTEGER(KIND=8). [var3] .\file2.f 733
Error 13 error #6410: This name has not been declared as an array or a function. [EQvar4] .\file2.f 645
Error 56 error #6410: This name has not been declared as an array or a function. [var2] .\file1.f 21
Error 31 error #6410: This name has not been declared as an array or a function. [var11] .\file2.f 696
Error 59 error #6410: This name has not been declared as an array or a function. [var111] .\file1.f 35
Error 14 error #6410: This name has not been declared as an array or a function. [var12] .\file2.f 650
Error 26 error #6410: This name has not been declared as an array or a function. [var12] .\file2.f 684
Error 58 error #6410: This name has not been declared as an array or a function. [var121] .\file1.f 34
Error 40 error #6410: This name has not been declared as an array or a function. [var8] .\file2.f 719
Error 29 error #6410: This name has not been declared as an array or a function. [var13] .\file2.f 690
Error 50 error #6410: This name has not been declared as an array or a function. [var131] .\file1.f 7
Error 27 error #6410: This name has not been declared as an array or a function. [var14] .\file2.f 685
Error 48 error #6410: This name has not been declared as an array or a function. [var141] .\file1.f 6
Error 18 error #6410: This name has not been declared as an array or a function. [var10] .\file2.f 662
Error 23 error #6410: This name has not been declared as an array or a function. [var10] .\file2.f 673
Error 54 error #6410: This name has not been declared as an array or a function. [var15] .\file1.f 9
Error 20 error #6410: This name has not been declared as an array or a function. [var16] .\file2.f 664
Error 21 error #6410: This name has not been declared as an array or a function. [var16] .\file2.f 667
Error 22 error #6410: This name has not been declared as an array or a function. [var16] .\file2.f 669
Error 24 error #6410: This name has not been declared as an array or a function. [var16] .\file2.f 675
Error 25 error #6410: This name has not been declared as an array or a function. [var16] .\file2.f 677
Error 28 error #6410: This name has not been declared as an array or a function. [var17] .\file2.f 687
Error 30 error #6410: This name has not been declared as an array or a function. [var17] .\file2.f 692
Error 52 error #6410: This name has not been declared as an array or a function. [var171] .\file1.f 8
Error 10 error #6423: This name has already been used as an external function name. [var4] .\file2.f 628
Error 55 error #6423: This name has already been used as an external function name. [var5] .\file1.f 14
Error 45 error #6423: This name has already been used as an external function name. [var7] .\file2.f 736
Error 11 error #6515: This function, which is specified as the left side of an assignment statement, is invalid. [var4] .\file2.f 628
Error 46 error #6515: This function, which is specified as the left side of an assignment statement, is invalid. [var7] .\file2.f 736
Error 64 error #6724: An allocate/deallocate object must have the ALLOCATABLE or POINTER attribute. [var18] .\Allocate.f 26
Error 62 error #6724: An allocate/deallocate object must have the ALLOCATABLE or POINTER attribute. [var19] .\Allocate.f 26
Error 3 error #7002: Error in opening the compiled module file. Check INCLUDE paths. [var20] .\file2.f 76
Error 4 error #7002: Error in opening the compiled module file. Check INCLUDE paths. [var21] .\file2.f 77
Error 1 error #7002: Error in opening the compiled module file. Check INCLUDE paths. [var22] .\file2.f 74
Error 2 error #7002: Error in opening the compiled module file. Check INCLUDE paths. [var23] .\file2.f 75
Error 65 error #8196: An ALLOCATE shape must not be given for a scalar object. [var18] .\Allocate.f 26
Error 63 error #8196: An ALLOCATE shape must not be given for a scalar object. [var19] .\Allocate.f 26
Error 66 Compilation Aborted (code 1) .\file2.f 1
Any help on the topic would be appreciated. It is urgent and I am stuck because of this. Looking forward for some response...thank you in advance...
Topic Options
