29375 Discussions
error #6200/6303/6341/6358/6385/6410/Visual Fortran Composer XE 2013 SP1 in Microsoft Visual Studio 2010
Vinod_K_
I had a working code (sources files + header file+ included files in .f) which was working fine. I had installed following system in my window10 Enterprise, then initially I got the error on license not found ( however license was found at the location mentioned in environment variable). I thought reinstalling should solve the issue. although it solve the license issues, but got a new bunch of errors in the working code which  I could not figure out the reason. A help would be appreciated on the same.
System info:
Version 10.0.30319.1 RTMRel
Microsoft .NET Framework
Version 4.7.02053 RTMRel
Installed Version: IDE Standard
Microsoft Visual Web Developer 2010   01011-532-2002361-70606
Intel(R) Visual Fortran     Package ID: w_fcompxe_2013_sp1.6.241
Intel(R) Visual Fortran Composer XE 2013 SP1 Update 6 Integration for Microsoft Visual Studio* 2010, 14.0.0100.2010, Copyright (C) 2002-2014 Intel Corporation
window 10 enterprise x64
Error details:
Error 49  error #6200: A colon (:) is not valid in this context. .\file1.f 6
Error 51  error #6200: A colon (:) is not valid in this context. .\file1.f 7
Error 53  error #6200: A colon (:) is not valid in this context. .\file1.f 8
Error 19  error #6303: The assignment operation or the binary expression operation is invalid for the data types of the two operands. .\file2.f 662
Error 36  error #6341: A logical data type is required in this context. .\file2.f 697
Error 8  error #6341: A logical data type is required in this context.   [var1] .\file2.f 626
Error 61  error #6341: A logical data type is required in this context.   [var1] .\file2.f 751
Error 57  error #6341: A logical data type is required in this context.   [var2] .\file1.f 21
Error 6  error #6341: A logical data type is required in this context.   [var3] .\file2.f 572
Error 43  error #6341: A logical data type is required in this context.   [var3] .\file2.f 733
Error 9  error #6358: Constants and expressions are invalid in read-only I/O lists.   [var4] .\file2.f 627
Error 12  error #6358: Constants and expressions are invalid in read-only I/O lists.   [var4] .\file2.f 630
Error 17  error #6358: Constants and expressions are invalid in read-only I/O lists.   [var5] .\file2.f 657
Error 15  error #6358: Constants and expressions are invalid in read-only I/O lists.   [var6] .\file2.f 653
Error 37  error #6358: Constants and expressions are invalid in read-only I/O lists.   [var6] .\file2.f 714
Error 44  error #6358: Constants and expressions are invalid in read-only I/O lists.   [var7] .\file2.f 734
Error 41  error #6358: Constants and expressions are invalid in read-only I/O lists.   [var8] .\file2.f 724
Error 16  error #6358: Constants and expressions are invalid in read-only I/O lists.   [Rvar4] .\file2.f 654
Error 38  error #6358: Constants and expressions are invalid in read-only I/O lists.   [Rvar4] .\file2.f 714
Error 47  error #6358: Constants and expressions are invalid in read-only I/O lists.   [var9] .\file2.f 741
Error 39  error #6358: Constants and expressions are invalid in read-only I/O lists.   [ROE] .\file2.f 715
Error 33  error #6385: The highest data type rank permitted is INTEGER(KIND=8). .\file2.f 697
Error 35  error #6385: The highest data type rank permitted is INTEGER(KIND=8). .\file2.f 697
Error 7  error #6385: The highest data type rank permitted is INTEGER(KIND=8).   [var1] .\file2.f 626
Error 60  error #6385: The highest data type rank permitted is INTEGER(KIND=8).   [var1] .\file2.f 751
Error 34  error #6385: The highest data type rank permitted is INTEGER(KIND=8).   [var5] .\file2.f 697
Error 32  error #6385: The highest data type rank permitted is INTEGER(KIND=8).   [var10] .\file2.f 697
Error 5  error #6385: The highest data type rank permitted is INTEGER(KIND=8).   [var3] .\file2.f 572
Error 42  error #6385: The highest data type rank permitted is INTEGER(KIND=8).   [var3] .\file2.f 733
Error 13  error #6410: This name has not been declared as an array or a function.   [EQvar4] .\file2.f 645
Error 56  error #6410: This name has not been declared as an array or a function.   [var2] .\file1.f 21
Error 31  error #6410: This name has not been declared as an array or a function.   [var11] .\file2.f 696
Error 59  error #6410: This name has not been declared as an array or a function.   [var111] .\file1.f 35
Error 14  error #6410: This name has not been declared as an array or a function.   [var12] .\file2.f 650
Error 26  error #6410: This name has not been declared as an array or a function.   [var12] .\file2.f 684
Error 58  error #6410: This name has not been declared as an array or a function.   [var121] .\file1.f 34
Error 40  error #6410: This name has not been declared as an array or a function.   [var8] .\file2.f 719
Error 29  error #6410: This name has not been declared as an array or a function.   [var13] .\file2.f 690
Error 50  error #6410: This name has not been declared as an array or a function.   [var131] .\file1.f 7
Error 27  error #6410: This name has not been declared as an array or a function.   [var14] .\file2.f 685
Error 48  error #6410: This name has not been declared as an array or a function.   [var141] .\file1.f 6
Error 18  error #6410: This name has not been declared as an array or a function.   [var10] .\file2.f 662
Error 23  error #6410: This name has not been declared as an array or a function.   [var10] .\file2.f 673
Error 54  error #6410: This name has not been declared as an array or a function.   [var15] .\file1.f 9
Error 20  error #6410: This name has not been declared as an array or a function.   [var16] .\file2.f 664
Error 21  error #6410: This name has not been declared as an array or a function.   [var16] .\file2.f 667
Error 22  error #6410: This name has not been declared as an array or a function.   [var16] .\file2.f 669
Error 24  error #6410: This name has not been declared as an array or a function.   [var16] .\file2.f 675
Error 25  error #6410: This name has not been declared as an array or a function.   [var16] .\file2.f 677
Error 28  error #6410: This name has not been declared as an array or a function.   [var17] .\file2.f 687
Error 30  error #6410: This name has not been declared as an array or a function.   [var17] .\file2.f 692
Error 52  error #6410: This name has not been declared as an array or a function.   [var171] .\file1.f 8
Error 10  error #6423: This name has already been used as an external function name.   [var4] .\file2.f 628
Error 55  error #6423: This name has already been used as an external function name.   [var5] .\file1.f 14
Error 45  error #6423: This name has already been used as an external function name.   [var7] .\file2.f 736
Error 11  error #6515: This function, which is specified as the left side of an assignment statement, is invalid.   [var4] .\file2.f 628
Error 46  error #6515: This function, which is specified as the left side of an assignment statement, is invalid.   [var7] .\file2.f 736
Error 64  error #6724: An allocate/deallocate object must have the ALLOCATABLE or POINTER attribute.   [var18] .\Allocate.f 26
Error 62  error #6724: An allocate/deallocate object must have the ALLOCATABLE or POINTER attribute.   [var19] .\Allocate.f 26
Error 3  error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [var20] .\file2.f 76
Error 4  error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [var21] .\file2.f 77
Error 1  error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [var22] .\file2.f 74
Error 2  error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [var23] .\file2.f 75
Error 65  error #8196: An ALLOCATE shape must not be given for a scalar object.   [var18] .\Allocate.f 26
Error 63  error #8196: An ALLOCATE shape must not be given for a scalar object.   [var19] .\Allocate.f 26
Error 66 Compilation Aborted (code 1) .\file2.f 1
Vinod_K_
Any help on the topic would be appreciated. It is urgent and I am stuck because of this. Looking forward for some response...thank you in advance...
