29434 Discussions
error#6405 for debug mode, not for release mode
Mingliang_Xie
Dear Sir(s),
I have been using Intel® Composer XE for Windows* (formerly Intel® Compiler Suite Professional Edition for Windows*).
My college has used a newer version of your compiler, and we worked on the same code. When I got the code back from him this time, I can compile it successfully with release mode, but failed with the debug mode.
The first error is:
Error    1     error #6405: The same named entity from different modules and/or program units cannot be referenced.   [FINDSTRG]    d:\MIN3P_THCm\min3p_thcm_v396Recheck\src\icesheet\m_ice_sheet.F90    1224
That’s however not the case, otherwise it will fail when compiled under release version.
The function findstrg is defined in the following subroutine, which has been applied over 400 times in the code without any problem before:
!c ----------------------------------------------------------------------
!c subroutine findstrg
!c find text string in data file
!c definition of variables:
!c
!c I --> on input   * arbitrary  - initialized  + entries expected
!c O --> on output  * arbitrary  - unaltered    + altered
!c        I O
!c passed:   integer*4:
!c           ----------
!c           itmp
!c
!c           logical:
!c           ---------
!c           found_subsection
!c
!c           character:
!c           ----------
!c           subsection
!c
!c common:   -
!c
!c local:    character:
!c           ----------
!c           string
      subroutine findstrg(subsection,itmp,found_subsection)
     implicit none
      character*72 subsection
      integer itmp
      logical found_subsection
      character*72 string
!c  rewind input file
      rewind(itmp)
!c  search for test string in input file
      found_subsection = .false.
      do while (.not.found_subsection)
        read(itmp,*,end=999) string
        if (string.eq.subsection) then
          found_subsection = .true.
        end if
      end do
999   return
      end
When it is called in the following subroutine more than once, the error occurs:
subroutine read_ice_sheet_block_ice_sheet  &
  (this, &
   idat, &
   istemp, &
   icetimeline, &
   iserror)
implicit none
external findstrg
!% Maximum pressure update in each timestep
subsection = 'maximum ice loading boundary pressure update'
call findstrg(subsection,idat,found)
if (found) then
  read(idat,*,err=10) max_update_pw
  b_check_update_pw = .true.
else
  b_check_update_pw = .false.
end if
subsection = 'maximum ice loading internal pressure update'
if (found) then
  read(idat,*,err=10) max_update_pice
  b_check_update_pice = .true.
else
  b_check_update_pice = .false.
end if
end
I tried also using interface to replace the 'external findstrg' before the subroutine including the code 'call findstrg' as suggested in the previous forum discussions, it failed with the same error.
Would you please help?
David
I have seen this before when the "Check routine interfaces" option is enabled, which it is by default in a Debug configuration. One instance of this bug was fixed in the 13.0 compiler - you may be using an older one.
The workaround for now is to set the project property Diagnostics > Check routine interfaces to No.
