28446 Discussions
error #6451: A dummy argument name is required in this context.
cean
New Contributor II
 I have one Module defines a Type like this:
TYPE MKL_DSS_HANDLE; INTEGER(KIND=8) DUMMY; END TYPE
In another Module where trying to use it like this:
TYPE(MKL_DSS_HANDLE),INTENT(OUT):: HANDLE
The compiling error is #6451: A dummy argument name is required in this context. [HANDLE]
I found another thread mentioned this error at here:
a strange problem - Intel Communities
But no clue how to fix my case.
Thank you for help.
Cheers
Cean
Arjen_Markus
Honored Contributor I
The program does not define a parameter "LONG", so it should come in via the module (or modules), but the source code as found in the zip file does not contain any definition of such a parameter. So the compiler complains about it.
jimdempseyatthecove
Is HANDLE one of the arguments to the function/subroutine?
Is HANDLE an fpp macro name?
If both answers are no, try changing (in both argument and argument declaration) HANDLE to H. If this works, then there is some sort of name collision. And if so, please present a simple reproducer.
Jim Dempsey
Steve_Lionel
HANDLE is a named (PARAMETER) constant in the Windows API declaration modules, but this declaration should hide that if it is accessible. The error message is suggesting that HANDLE isn't a dummy argument of the procedure containing this declaration - the INTENT(OUT) attribute requires that.
I'll comment that, with compiler error messages, context is everything - especially so for Fortran. Showing a single statement, especially one that complains about dummy arguments, doesn't give enough detail for us to help you. As Jim suggests, a minimal reproducer helps a lot.
cean
New Contributor II
Thanks all.
I changed the name HANDLE to BJHANDLE, still the same error.
It Is one of the arguments to a function.  It is called like this:
IntMKL_IER = DSS_CREATE ( BJHANDLE, opt )
 This DSS_CREATE function is in module A:
      INTERFACE
        FUNCTION DSS_CREATE( HANDLE, OPT )
          USE MKL_DSS_PRIVATE
          TYPE(MKL_DSS_HANDLE), INTENT(OUT)   :: HANDLE
          INTEGER,              INTENT(IN)    :: OPT
          INTEGER                             :: DSS_CREATE
        END FUNCTION DSS_CREATE
      END INTERFACE
Module USE MKL_DSS_PRIVATE has that Type declaration.
Module A also use MKL_DSS_PRIVATE.
Ron_Green
there's not enough to go on here.  Do you have something we can compile?
And you didn't mention what version of the compiler you are using.  Is this the latest v2022 compiler?  Ifort and not IFX, correct?
cean
New Contributor II
I am using VS 17.3.2 + IFC w_oneAPI_2022.1.0.256.
I am trying to make a little program:
    program Console4
    USE MKL_DSS
    IMPLICIT NONE
    TYPE(MKL_DSS_HANDLE)            :: HANDLE
    INTEGER(LONG)                   :: OPT               ! Option indicator for Intel MKL dss routines
    INTEGER(LONG)                   :: IntMKL_IER        ! Intel MKL error code (see MKL documentation for values)
    OPT = MKL_DSS_MSG_LVL_WARNING
    IntMKL_IER = DSS_CREATE ( HANDLE, OPT )
    end program Console4
It calls Function DSS_CREATE which is in MKL_DSS.f90
MKL_DSS.f90 needs MKL_DSS_PRIVATE.f90.  It declares TYPE MKL_DSS_HANDLE.
This is an old program and inside MKL_DSS.f90 it says these two modules are from an old MKL example.
But the error now is:
error #6683: A kind type parameter must be a compile-time constant. [LONG]
Arjen_Markus
cean
New Contributor II
I added LONG.
    program Console4
    USE MKL_DSS
    IMPLICIT NONE
    INTEGER, PARAMETER :: LONG   =  4
 Now the error is:
error LNK2019: unresolved external symbol DSS_CREATE referenced in function MAIN_
Why it can't find that Function inside MKL_DSS.f90?
Also this test program doesn't demonstrate the error in my real program.
Andreas_Z_
In this case, the error goes away by linking to the MKL library (e.g. /Qmkl:parallel). In VS this is set under project properties > Fortran > Libraries
cean
New Contributor II
Found a dss_sym_f90.f90 at mkl\2022.1.0\examples\core\sparse_directsolvers\source. It is the same function as what I want. I can compile it with no problem.
Need to figure out what went wrong for my version.
