error #7062
sstouli
Hi all,
I am trying to compile the attached code on Intel Fortran 11.1 for Windows XP (on Visual Studio 2008). The code can be compiled under version 10.1 but under the version 11.1 I get the following error message:
#7062: The characteristics of dummy argument 2 of the associated actual procedure differ from the characteristics of dummy argument 2 of the dummy procedure.
I guess it comes from the interface when passing a function as an argument to a routine but I can't fix it.
Thanks very much in advance for any replies.
Best
Yes, you can fix it. The problem is that the INTENT attributes are inconsistent. The standard says that these must match when you are passing a procedure as an argument. 10.1 didn't catch this error.
sstouli
Thank you Steve. It works now.
