error code 23 (returned by OpenValidateX) …errors with visual studio 2015 > intel visual Fortran compiler > console application
John_C_
am running a visual studio 2015 > intel visual Fortran compiler > console application project .so I added these files. I want to get DLLs and call them from somewhere else.(maybe I must use another type of visual Fortran compiler projects, I am not sure) I only make an empty consol application of visual Fortran compiler ,then add my .f90 Fortran files.and then run the project.so I got errors.maybe another routine must be done. alloc_after_mesh.f90 arint3D.f90 baric.f90 blomamor.f90 blomamorc.f90 blomamorp.f90 bloseg3D.f90 bloseg3Dc.f90 calindc.f90 calprebloqueo.f90 calvnoru.f90 cg.f90 cgrevcom.f90 comprobaciones.f90 conlud.f90 creamake.dat derff.f90 ef_el.f90 electrostatica3D.f90 endat3D.f90 ensacmor.f90 funciones3D.f90 gauspp.f90 leema3D.f90 leetmp.f90 Makefile Makefile.windows matlap_orto.f90 matriz3D_orto.f90 matvec.f90 modulos_electros3D.f90 mod_mcambio.f90 norl2_3D.f90 [object] principal.f90 procb1.f90 procb2.f90 psolve.f90 punto1.f90 readxml.f90 reslud.f90 semi3D.f90 stoptest2.f90 wrtcmp.f90 wrtcmpv.f90 but when compiling I got these errors: error code 23 (returned by OpenValidateX) Compilation Aborted (code 1) error #7002: Error in opening the compiled module and so far... Severity Code Description Project File Line Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\semi3D.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\alloc_after_mesh.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\arint3D.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\baric.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\blomamor.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\blomamorc.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\blomamorp.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\bloseg3D.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\bloseg3Dc.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\calindc.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\calprebloqueo.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\calvnoru.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\cg.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\cgrevcom.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\comprobaciones.f90 1 Error Compilation Aborted (code 1) C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\comprobaciones.f90 1 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MESH] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\comprobaciones.f90 7 Error error #6404: This name does not have a type, and must have an explicit type. [MESH_READ_ARRAY_UNFORMATTED] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\comprobaciones.f90 203 Error error #6404: This name does not have a type, and must have an explicit type. [MESH_ERROR_STRING] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\comprobaciones.f90 206 Error error #6362: The data types of the argument(s) are invalid. [TRIM] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\comprobaciones.f90 206 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\conlud.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\derff.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\ef_el.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\electrostatica3D.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\endat3D.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\ensacmor.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\funciones3D.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\gauspp.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 1 Error Compilation Aborted (code 1) C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 1 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_COMPILER_DEPENDANT] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 19 Error error #6580: Name in only-list does not exist. [IOSTAT_END] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 19 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_CONVER3D] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 24 Error error #6580: Name in only-list does not exist. [CONVER3D] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 24 Error error #6404: This name does not have a type, and must have an explicit type. [IOSTAT_END] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 89 Error error #6406: Conflicting attributes or multiple declaration of name. [CONVER3D] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 90 Error error #6406: Conflicting attributes or multiple declaration of name. [CONVER3D] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 170 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 1 Error Compilation Aborted (code 1) C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 1 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_CONVERS] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 9 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [LIB_VTK_IO_READ] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 10 Error error #6404: This name does not have a type, and must have an explicit type. [LCASE] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 19 Error error #6608: In a CASE statement, the case-expr must be of type INTEGER, CHARACTER, or LOGICAL. [LCASE] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 19 Error error #6611: The case-value must be of the same type as the case-expr. ['mff'] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 20 Error error #6611: The case-value must be of the same type as the case-expr. ['vtu'] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 31 Error error #6404: This name does not have a type, and must have an explicit type. [VTK_INI_XML_READ] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 33 Error error #6404: This name does not have a type, and must have an explicit type. [VTK_VAR_XML_READ] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 36 Error error #6404: This name does not have a type, and must have an explicit type. [VTK_END_XML_READ] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 38 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\matlap_orto.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\matriz3D_orto.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\matvec.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\modulos_electros3D.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\mod_mcambio.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\norl2_3D.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 1 Error Compilation Aborted (code 1) C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 1 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_WRITEVTU] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 29 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [COMPROBACIONES] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 30 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_CONVERS] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 31 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_FEM_EXTRACT] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 32 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_CONVER3D] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 33 Error error #6580: Name in only-list does not exist. [CONVER3D] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 33 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [LIB_VTK_IO_READ] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 34 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_READUNV] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 35 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_COMPILER_DEPENDANT] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 36 Error error #6683: A kind type parameter must be a compile-time constant. [REAL64] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 41 Error error #6404: This name does not have a type, and must have an explicit type. [COMPRUEBA] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 54 Error error #6404: This name does not have a type, and must have an explicit type. [ERROR_UNIT] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 55 Error error #6404: This name does not have a type, and must have an explicit type. [OUTPUT_UNIT] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 58 Error error #6404: This name does not have a type, and must have an explicit type. [BLOCKING_NODE] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 64 Error error #6404: This name does not have a type, and must have an explicit type. [LCASE] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 76 Error error #6608: In a CASE statement, the case-expr must be of type INTEGER, CHARACTER, or LOGICAL. [LCASE] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 76 Error error #6611: The case-value must be of the same type as the case-expr. ['mfm'] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 77 Error error #6611: The case-value must be of the same type as the case-expr. ['mum'] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 80 Error error #6611: The case-value must be of the same type as the case-expr. ['unv'] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 83 Error error #6406: Conflicting attributes or multiple declaration of name. [CONVER3D] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 85 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\procb1.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\procb2.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\psolve.f90 1 Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\punto1.f90 1 Error Compilation Aborted (code 1) C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 1 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_SO_DEPENDANT] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 7 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_REPORT] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 8 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_XML_PARSER] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 9 Error error #6683: A kind type parameter must be a compile-time constant. [DOUBLE] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 24 Error error #6683: A kind type parameter must be a compile-time constant. [DOUBLE] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 25 Error error #6404: This name does not have a type, and must have an explicit type. [REPORT_STDOUT] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 29 Error error #6404: This name does not have a type, and must have an explicit type. [FOPEN] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 39 Error error #6632: Keyword arguments are invalid without an explicit interface. [REALLOC] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 58 Error error #6362: The data types of the argument(s) are invalid. [INT] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 66 Error error #6632: Keyword arguments are invalid without an explicit interface. [REALLOC] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 77 Error error #6362: The data types of the argument(s) are invalid. [INT] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 85 Error error #6632: Keyword arguments are invalid without an explicit interface. [REALLOC] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 110 ... what should I do, any help will be appreciated. updated #1 my Makefile.windows is as below: ################################################################# # Makefile created using the tool 'Creamake' # # Creamake is distributed under the GNU GPL license # Author: Francisco Pena, fran.pena@usc.es # Download page: http://sourceforge.net/projects/creamake/ ################################################################# ################################################################# # User-modifiable options ################################################################# # SOURCE AND COMMONS FOLDERS (separated by spaces) dir_fuentes = . ..\other\blas ..\other\basicmod ..\other\common ..\other\fem \ ..\other\unv ..\other\xml ..\other\vtu ..\other\conver3d # OBJECT AND .MOD FOLDER dir_objetos = object # MAIN SOURCE FILE (include relative path from folder where Makefile is) condir_principal = .\principal.f90 # EXECUTABLE NAME ejecutable = ..\..\solvers\electrostatics3d.exe # NEEDED TO convert ejecutable THE DEFAULT RULE: $(ejecutable): $(condir_principal) # MODULES modulos = comprobaciones.f90 mod_mcambio.f90 modulos_electros3D.f90 \ module_ALLOC_char_r1.f90 module_ALLOC.f90 module_ALLOC_int_alloc_r2.f90 \ module_ALLOC_int_r1.f90 module_ALLOC_int_r2.f90 module_ALLOC_log_r2.f90 \ module_ALLOC_real_alloc_r2.f90 module_ALLOC_real_DOUBLE_r1.f90 \ module_ALLOC_real_DOUBLE_r2.f90 module_ALLOC_real_r1.f90 \ module_ALLOC_real_r2.f90 module_COMPILER_DEPENDANT.f90 module_CONVERS.f90 \ module_FILES.f90 module_REPORT.f90 module_SO_DEPENDANT.f90 defines.f90 mesh.f90 \ subdomains.f90 vector.f90 module_fem_extract_complex.f90 module_fem_extract.f90 \ module_fem_extract_real.f90 module_bsearch.f90 module_cells.f90 \ module_dataset_2411.f90 module_dataset_2412.f90 module_dataset_2467.f90 \ module_dataset.f90 module_FE_DB.f90 module_groups.f90 module_mesh.f90 \ module_readUNV.f90 module_unv.f90 module_xml_parser.f90 LIB_VTK_IO.f90 \ LIB_VTK_IO_READ.f90 module_writeVTU.f90 module_conver3d.f90 \ module_conver3d_source.f # DEPENDENCIAS ENTRE MODULOS # si pru1 depende de pru2... pru1.o: pru2.o comprobaciones.obj: mesh.obj modulos_electros3D.obj modulos_electros3D.obj \ modulos_electros3D.obj modulos_electros3D.obj modulos_electros3D.obj \ modulos_electros3D.obj modulos_electros3D.obj modulos_electros3D.obj \ modulos_electros3D.obj mod_mcambio.obj: modulos_electros3D.obj modulos_electros3D.obj: module_ALLOC_char_r1.obj: module_REPORT.obj module_ALLOC.obj: module_ALLOC_int_r1.obj module_ALLOC_int_r2.obj \ module_ALLOC_int_alloc_r2.obj module_ALLOC_real_r1.obj module_ALLOC_real_r2.obj \ module_ALLOC_real_alloc_r2.obj module_ALLOC_real_DOUBLE_r1.obj \ module_ALLOC_real_DOUBLE_r2.obj module_ALLOC_char_r1.obj module_ALLOC_log_r2.obj module_ALLOC_int_alloc_r2.obj: module_ALLOC_int_r1.obj module_ALLOC_int_r1.obj: module_REPORT.obj module_ALLOC_int_r2.obj: module_REPORT.obj module_ALLOC_log_r2.obj: module_REPORT.obj module_ALLOC_real_alloc_r2.obj: module_ALLOC_real_r1.obj module_ALLOC_real_DOUBLE_r1.obj: module_COMPILER_DEPENDANT.obj module_REPORT.obj module_ALLOC_real_DOUBLE_r2.obj: module_COMPILER_DEPENDANT.obj module_REPORT.obj module_ALLOC_real_r1.obj: module_REPORT.obj module_ALLOC_real_r2.obj: module_REPORT.obj module_CONVERS.obj: module_COMPILER_DEPENDANT.obj module_REPORT.obj module_FILES.obj: module_REPORT.obj module_CONVERS.obj module_REPORT.obj: module_COMPILER_DEPENDANT.obj module_SO_DEPENDANT.obj module_SO_DEPENDANT.obj: module_COMPILER_DEPENDANT.obj defines.obj: module_COMPILER_DEPENDANT.obj mesh.obj: defines.obj subdomains.obj: defines.obj vector.obj: defines.obj module_fem_extract.obj: module_fem_extract_real.obj \ module_fem_extract_complex.obj module_dataset_2411.obj: module_COMPILER_DEPENDANT.obj module_ALLOC.obj \ module_dataset.obj module_mesh.obj module_dataset_2412.obj: module_ALLOC.obj module_dataset.obj module_mesh.obj \ module_FE_DB.obj module_cells.obj module_dataset_2467.obj: module_dataset.obj module_mesh.obj module_cells.obj \ module_groups.obj module_dataset.obj: module_REPORT.obj module_CONVERS.obj module_FE_DB.obj: module_COMPILER_DEPENDANT.obj module_groups.obj: module_ALLOC.obj module_mesh.obj: module_COMPILER_DEPENDANT.obj module_ALLOC.obj module_FILES.obj module_readUNV.obj: module_COMPILER_DEPENDANT.obj module_SO_DEPENDANT.obj \ module_CONVERS.obj module_unv.obj module_mesh.obj module_unv.obj: module_ALLOC.obj module_FILES.obj module_mesh.obj \ module_dataset_2411.obj module_dataset_2412.obj module_dataset_2467.obj \ module_bsearch.obj module_xml_parser.obj: module_ALLOC.obj module_CONVERS.obj module_REPORT.obj \ module_FILES.obj LIB_VTK_IO_READ.obj: LIB_VTK_IO.obj module_writeVTU.obj: LIB_VTK_IO.obj module_conver3d.obj: module_COMPILER_DEPENDANT.obj module_conver3d_source.obj # INCLUDES includes = # COMPILER FC = gfortran # COMPILER OPTIONS FFLAGS = -J$(dir_objetos) -ffree-line-length-0 -ffixed-line-length-0 # LINKER OPTIONS LDFLAGS = -static ################################################################# # Non-modifiable part ################################################################# # CARPETAS DE BUSQUEDA VPATH = $(subst ,:,$(strip $(dir_fuentes))) vpath %.obj $(dir_objetos) # FUENTES fuentes_ = $(filter %.f %.F %.for %.FOR %.f90 %.F90 %.f95 %.F95 %.f03 %.F03,$(shell dir /b $(dir_fuentes))) fuentes = $(filter-out $(notdir $(condir_principal)) $(modulos),$(fuentes_)) # OBJETOS modulos_obj = $(addsuffix .obj,$(basename $(modulos))) fuentes_obj = $(addsuffix .obj,$(basename $(fuentes))) # OBJETOS EN SU CARPETA condir_modulos_obj = $(addprefix $(dir_objetos)/,$(modulos_obj)) condir_fuentes_obj = $(addprefix $(dir_objetos)/,$(fuentes_obj)) # OPCIONES DE COMPILACION FFLAGS += $(patsubst %,-I%,$(dir_fuentes)) FFLAGS += -I$(dir_objetos) # REGLA PRINCIPAL all: $(ejecutable) $(ejecutable): $(includes) $(modulos_obj) $(fuentes_obj) $(FC) -o $(ejecutable) $(FFLAGS) $(condir_principal) $(condir_modulos_obj) $(condir_fuentes_obj) $(LDFLAGS) # REGLA PARA LAS FUENTES $(fuentes_obj): $(includes) $(modulos_obj) # PATRONES DE REGLAS %.obj:%.f $(FC) -c -o $@ $(FFLAGS) $< @copy $@ $(dir_objetos) @del $@ %.obj:%.F $(FC) -c -o $@ $(FFLAGS) $< @copy $@ $(dir_objetos) @del $@ %.obj:%.for $(FC) -c -o $@ $(FFLAGS) $< @copy $@ $(dir_objetos) @del $@ %.obj:%.FOR $(FC) -c -o $@ $(FFLAGS) $< @copy $@ $(dir_objetos) @del $@ %.obj:%.f90 $(FC) -c -o $@ $(FFLAGS) $< @copy $@ $(dir_objetos) @del $@ %.obj:%.F90 $(FC) -c -o $@ $(FFLAGS) $< @copy $@ $(dir_objetos) @del $@ .PHONY: clean clean: del $(dir_objetos)\*.obj del $(dir_objetos)\*.mod del $(ejecutable)
Steve_Lionel
This is a VS bug fixed in a VS update. Install the latest VS update. It is otherwise harmless.
John_C_
I use Microsoft visual studio enterprise 2015 version 14.0.23107.10 Should I update that?if yes to which version?should I use vs2017 instead? Regards
Steve_Lionel
Update VS2015. https://msdn.microsoft.com/en-us/library/mt752379.aspx is Update 3. You can use VS2017 if you have Intel Parallel Studio XE 2017 Update 4.
John_C_
I updated my vs to vs2015 update3 as you said.but I got new errors as below Severity Code Description Project File Line Suppression State Error Compilation Aborted (code 1) C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\comprobaciones.f90 1 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MESH] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\comprobaciones.f90 7 Error error #6404: This name does not have a type, and must have an explicit type. [MESH_READ_ARRAY_UNFORMATTED] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\comprobaciones.f90 203 Error error #6404: This name does not have a type, and must have an explicit type. [MESH_ERROR_STRING] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\comprobaciones.f90 206 Error error #6362: The data types of the argument(s) are invalid. [TRIM] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\comprobaciones.f90 206 Error Compilation Aborted (code 1) C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 1 Error error #6580: Name in only-list does not exist. [IOSTAT_END] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 19 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_COMPILER_DEPENDANT] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 19 Error error #6580: Name in only-list does not exist. [CONVER3D] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 24 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_CONVER3D] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 24 Error error #6404: This name does not have a type, and must have an explicit type. [IOSTAT_END] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 89 Error error #6406: Conflicting attributes or multiple declaration of name. [CONVER3D] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 90 Error error #6406: Conflicting attributes or multiple declaration of name. [CONVER3D] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 170 Error Compilation Aborted (code 1) C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 1 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_CONVERS] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 9 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [LIB_VTK_IO_READ] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 10 Error error #6404: This name does not have a type, and must have an explicit type. [LCASE] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 19 Error error #6608: In a CASE statement, the case-expr must be of type INTEGER, CHARACTER, or LOGICAL. [LCASE] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 19 Error error #6611: The case-value must be of the same type as the case-expr. ['mff'] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 20 Error error #6611: The case-value must be of the same type as the case-expr. ['vtu'] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 31 Error error #6404: This name does not have a type, and must have an explicit type. [VTK_INI_XML_READ] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 33 Error error #6404: This name does not have a type, and must have an explicit type. [VTK_VAR_XML_READ] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 36 Error error #6404: This name does not have a type, and must have an explicit type. [VTK_END_XML_READ] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 38 Error Compilation Aborted (code 1) C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 1 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_WRITEVTU] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 29 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [COMPROBACIONES] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 30 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_CONVERS] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 31 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_FEM_EXTRACT] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 32 Error error #6580: Name in only-list does not exist. [CONVER3D] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 33 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_CONVER3D] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 33 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [LIB_VTK_IO_READ] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 34 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_READUNV] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 35 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_COMPILER_DEPENDANT] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 36 Error error #6683: A kind type parameter must be a compile-time constant. [REAL64] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 41 Error error #6404: This name does not have a type, and must have an explicit type. [COMPRUEBA] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 54 Error error #6404: This name does not have a type, and must have an explicit type. [ERROR_UNIT] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 55 Error error #6404: This name does not have a type, and must have an explicit type. [OUTPUT_UNIT] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 58 Error error #6404: This name does not have a type, and must have an explicit type. [BLOCKING_NODE] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 64 Error error #6404: This name does not have a type, and must have an explicit type. [LCASE] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 76 Error error #6608: In a CASE statement, the case-expr must be of type INTEGER, CHARACTER, or LOGICAL. [LCASE] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 76 Error error #6611: The case-value must be of the same type as the case-expr. ['mfm'] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 77 Error error #6611: The case-value must be of the same type as the case-expr. ['mum'] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 80 Error error #6611: The case-value must be of the same type as the case-expr. ['unv'] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 83 Error error #6406: Conflicting attributes or multiple declaration of name. [CONVER3D] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 85 Error Compilation Aborted (code 1) C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 1 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_SO_DEPENDANT] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 7 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_REPORT] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 8 Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_XML_PARSER] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 9 Error error #6683: A kind type parameter must be a compile-time constant. [DOUBLE] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 24 Error error #6683: A kind type parameter must be a compile-time constant. [DOUBLE] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 25 Error error #6404: This name does not have a type, and must have an explicit type. [REPORT_STDOUT] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 29 Error error #6404: This name does not have a type, and must have an explicit type. [FOPEN] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 39 Error error #6632: Keyword arguments are invalid without an explicit interface. [REALLOC] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 58 Error error #6362: The data types of the argument(s) are invalid. [INT] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 66 Error error #6632: Keyword arguments are invalid without an explicit interface. [REALLOC] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 77 Error error #6362: The data types of the argument(s) are invalid. [INT] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 85 Error error #6632: Keyword arguments are invalid without an explicit interface. [REALLOC] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 110 Error error #6362: The data types of the argument(s) are invalid. [INT] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 118 Error error #6632: Keyword arguments are invalid without an explicit interface. [REALLOC] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 129 Error error #6362: The data types of the argument(s) are invalid. [INT] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 137 Error error #6632: Keyword arguments are invalid without an explicit interface. [REALLOC] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 201 Error error #6362: The data types of the argument(s) are invalid. [INT] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 208 Error error #6632: Keyword arguments are invalid without an explicit interface. [REALLOC] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 221 Error error #6362: The data types of the argument(s) are invalid. [INT] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 228 Error error #6632: Keyword arguments are invalid without an explicit interface. [REALLOC] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 251 Error error #6362: The data types of the argument(s) are invalid. [INT] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 258 Error error #6632: Keyword arguments are invalid without an explicit interface. [REALLOC] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 271 Error error #6362: The data types of the argument(s) are invalid. [INT] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 278 Error error #6632: Keyword arguments are invalid without an explicit interface. [REALLOC] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 301 Error error #6362: The data types of the argument(s) are invalid. [INT] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 308 Error error #6632: Keyword arguments are invalid without an explicit interface. [REALLOC] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 321 Error error #6362: The data types of the argument(s) are invalid. [INT] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 328 Error error #6632: Keyword arguments are invalid without an explicit interface. [REALLOC] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 348 Error error #6632: Keyword arguments are invalid without an explicit interface. [REALLOC] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 350 Error error #6632: Keyword arguments are invalid without an explicit interface. [REALLOC] C:\Users\admin\documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 352 What should I do? Maybe depended to my f90 file's content.maybe I must fallow the makefile (that was for mingw gcc Command line) instruction in VS? Best regards
Steve_Lionel
The first error "error opening the compiled module file" is critical - you left off the rest of the message so I don't know which module it wanted.  Adding all the .f90 files to the project should be sufficient.
John_C_
Thanks.I added all f90 and f files prerequisites for the project.so the project compiled successfully.no errors.but I want to make DLL from f90 files to use in web or any where else.this is a console application.I see running and output of the compiled files in console.if its possible introduce me web links related. Regards
gib
New Contributor II
You created your project as a Console Application.  You need to create a new project as a Library, and select DLL.
John_C_
Hi,I do that.project built successfully but I got this error Visual studio cannot debug because a debug target has not been specified. So what should I do?
jimdempseyatthecove
gib>>You created your project as a Console Application.  You need to create a new project as a Library, and select DLL.
JohnC>>I do that.project built successfully but I got this error...Visual studio cannot debug because a debug target has not been specified.
You cannot run a DLL directly, thus no startup project.
Your Visual Studio Solution can have multiple Projects. In your case, for starters, you need a small test console application Project, plus your new DLL Project. The small test Project is to be set dependent upon the DLL project. Your test console project makes test calls to your DLL.
In MS VS you will need to specify the Startup Project as the console application (Right-Click on the Test Project in the Solution Explorer pane and click on Select Startup Project.
Jim Dempsey
John_C_
As a brief: 1. I have some Fortran .f90 files. 2 I installed visual Fortran compiler in visual studio 2015 I created library DLL empty project. I added all .f90 and .f files to the project. 5 I compiled the project. 6 now I have myproject.dll file. 7.I created a web application. 8 I try to add myproject.dll to references. 9.I got this error in visual studio environment before compile. : reference manager: A reference to path//myDLL.dll could not be added.please make sure that the file is accessible,and that is a valid assembly or COM component. Which project type knows my dll?.is there any error in compile of my dll?therefore what should I do? Which version of Fortran dll is compatible with c# ASP.NET web application ,something like http://www.c-sharpcorner.com/UploadFile/1e050f/creating-and-using-dll-class-library-in-C-Sharp/ At all my question is that how could I use .dll files created with visual Fortran compiler >library>DLL? Best regards
John_C_
Any help Wil be appreciated
John_C_
gib
New Contributor II
As far as I am aware the issues around accessing a DLL from a C# program are not Fortran issues.  It is possible that you need to tell the C# linker about the .lib file that was created together with the DLL.
