am running a visual studio 2015 > intel visual Fortran compiler > console application project .so I added these files. I want to get DLLs and call them from somewhere else.(maybe I must use another type of visual Fortran compiler projects, I am not sure)
I only make an empty consol application of visual Fortran compiler ,then add my .f90 Fortran files.and then run the project.so I got errors.maybe another routine must be done.
alloc_after_mesh.f90 arint3D.f90
baric.f90 blomamor.f90 blomamorc.f90 blomamorp.f90
bloseg3D.f90 bloseg3Dc.f90 calindc.f90 calprebloqueo.f90
calvnoru.f90 cg.f90 cgrevcom.f90 comprobaciones.f90
conlud.f90 creamake.dat derff.f90 ef_el.f90
electrostatica3D.f90 endat3D.f90 ensacmor.f90 funciones3D.f90
gauspp.f90 leema3D.f90 leetmp.f90 Makefile
Makefile.windows matlap_orto.f90 matriz3D_orto.f90 matvec.f90
modulos_electros3D.f90 mod_mcambio.f90 norl2_3D.f90 [object]
principal.f90 procb1.f90 procb2.f90 psolve.f90
punto1.f90 readxml.f90 reslud.f90 semi3D.f90
stoptest2.f90 wrtcmp.f90 wrtcmpv.f90
but when compiling I got these errors:
error code 23 (returned by OpenValidateX) Compilation Aborted (code 1) error #7002: Error in opening the compiled module and so far...
Severity Code Description Project File Line
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\semi3D.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\alloc_after_mesh.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\arint3D.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\baric.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\blomamor.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\blomamorc.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\blomamorp.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\bloseg3D.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\bloseg3Dc.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\calindc.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\calprebloqueo.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\calvnoru.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\cg.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\cgrevcom.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\comprobaciones.f90 1
Error Compilation Aborted (code 1) C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\comprobaciones.f90 1
Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MESH] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\comprobaciones.f90 7
Error error #6404: This name does not have a type, and must have an explicit type. [MESH_READ_ARRAY_UNFORMATTED] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\comprobaciones.f90 203
Error error #6404: This name does not have a type, and must have an explicit type. [MESH_ERROR_STRING] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\comprobaciones.f90 206
Error error #6362: The data types of the argument(s) are invalid. [TRIM] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\comprobaciones.f90 206
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\conlud.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\derff.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\ef_el.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\electrostatica3D.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\endat3D.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\ensacmor.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\funciones3D.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\gauspp.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 1
Error Compilation Aborted (code 1) C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 1
Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_COMPILER_DEPENDANT] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 19
Error error #6580: Name in only-list does not exist. [IOSTAT_END] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 19
Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_CONVER3D] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 24
Error error #6580: Name in only-list does not exist. [CONVER3D] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 24
Error error #6404: This name does not have a type, and must have an explicit type. [IOSTAT_END] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 89
Error error #6406: Conflicting attributes or multiple declaration of name. [CONVER3D] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 90
Error error #6406: Conflicting attributes or multiple declaration of name. [CONVER3D] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leema3D.f90 170
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 1
Error Compilation Aborted (code 1) C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 1
Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_CONVERS] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 9
Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [LIB_VTK_IO_READ] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 10
Error error #6404: This name does not have a type, and must have an explicit type. [LCASE] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 19
Error error #6608: In a CASE statement, the case-expr must be of type INTEGER, CHARACTER, or LOGICAL. [LCASE] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 19
Error error #6611: The case-value must be of the same type as the case-expr. ['mff'] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 20
Error error #6611: The case-value must be of the same type as the case-expr. ['vtu'] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 31
Error error #6404: This name does not have a type, and must have an explicit type. [VTK_INI_XML_READ] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 33
Error error #6404: This name does not have a type, and must have an explicit type. [VTK_VAR_XML_READ] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 36
Error error #6404: This name does not have a type, and must have an explicit type. [VTK_END_XML_READ] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\leetmp.f90 38
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\matlap_orto.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\matriz3D_orto.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\matvec.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\modulos_electros3D.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\mod_mcambio.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\norl2_3D.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 1
Error Compilation Aborted (code 1) C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 1
Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_WRITEVTU] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 29
Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [COMPROBACIONES] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 30
Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_CONVERS] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 31
Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_FEM_EXTRACT] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 32
Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_CONVER3D] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 33
Error error #6580: Name in only-list does not exist. [CONVER3D] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 33
Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [LIB_VTK_IO_READ] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 34
Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_READUNV] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 35
Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_COMPILER_DEPENDANT] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 36
Error error #6683: A kind type parameter must be a compile-time constant. [REAL64] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 41
Error error #6404: This name does not have a type, and must have an explicit type. [COMPRUEBA] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 54
Error error #6404: This name does not have a type, and must have an explicit type. [ERROR_UNIT] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 55
Error error #6404: This name does not have a type, and must have an explicit type. [OUTPUT_UNIT] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 58
Error error #6404: This name does not have a type, and must have an explicit type. [BLOCKING_NODE] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 64
Error error #6404: This name does not have a type, and must have an explicit type. [LCASE] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 76
Error error #6608: In a CASE statement, the case-expr must be of type INTEGER, CHARACTER, or LOGICAL. [LCASE] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 76
Error error #6611: The case-value must be of the same type as the case-expr. ['mfm'] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 77
Error error #6611: The case-value must be of the same type as the case-expr. ['mum'] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 80
Error error #6611: The case-value must be of the same type as the case-expr. ['unv'] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 83
Error error #6406: Conflicting attributes or multiple declaration of name. [CONVER3D] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\principal.f90 85
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\procb1.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\procb2.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\psolve.f90 1
Error error code 23 (returned by OpenValidateX) opening pdb Debug\vc140.pdb C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\punto1.f90 1
Error Compilation Aborted (code 1) C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 1
Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_SO_DEPENDANT] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 7
Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_REPORT] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 8
Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MODULE_XML_PARSER] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 9
Error error #6683: A kind type parameter must be a compile-time constant. [DOUBLE] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 24
Error error #6683: A kind type parameter must be a compile-time constant. [DOUBLE] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 25
Error error #6404: This name does not have a type, and must have an explicit type. [REPORT_STDOUT] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 29
Error error #6404: This name does not have a type, and must have an explicit type. [FOPEN] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 39
Error error #6632: Keyword arguments are invalid without an explicit interface. [REALLOC] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 58
Error error #6362: The data types of the argument(s) are invalid. [INT] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 66
Error error #6632: Keyword arguments are invalid without an explicit interface. [REALLOC] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 77
Error error #6362: The data types of the argument(s) are invalid. [INT] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 85
Error error #6632: Keyword arguments are invalid without an explicit interface. [REALLOC] C:\Users\admin\Documents\maxfem test for ifort A\maxfem_0.3.4_source\maxfem_0.3.4_source\sources\electrostatics3d\readxml.f90 110
what should I do, any help will be appreciated.
updated #1 my Makefile.windows is as below:
# Makefile created using the tool 'Creamake'
# Creamake is distributed under the GNU GPL license
# Author: Francisco Pena, fran.pena@usc.es
# Download page:
http://sourceforge.net/projects/creamake/
# User-modifiable options
# SOURCE AND COMMONS FOLDERS (separated by spaces)
dir_fuentes = . ..\other\blas ..\other\basicmod ..\other\common ..\other\fem \
..\other\unv ..\other\xml ..\other\vtu ..\other\conver3d
# OBJECT AND .MOD FOLDER
dir_objetos = object
# MAIN SOURCE FILE (include relative path from folder where Makefile is)
condir_principal = .\principal.f90
# EXECUTABLE NAME
ejecutable = ..\..\solvers\electrostatics3d.exe
# NEEDED TO convert ejecutable THE DEFAULT RULE:
$(ejecutable): $(condir_principal)
# MODULES
modulos = comprobaciones.f90 mod_mcambio.f90 modulos_electros3D.f90 \
module_ALLOC_char_r1.f90 module_ALLOC.f90 module_ALLOC_int_alloc_r2.f90 \
module_ALLOC_int_r1.f90 module_ALLOC_int_r2.f90 module_ALLOC_log_r2.f90 \
module_ALLOC_real_alloc_r2.f90 module_ALLOC_real_DOUBLE_r1.f90 \
module_ALLOC_real_DOUBLE_r2.f90 module_ALLOC_real_r1.f90 \
module_ALLOC_real_r2.f90 module_COMPILER_DEPENDANT.f90 module_CONVERS.f90 \
module_FILES.f90 module_REPORT.f90 module_SO_DEPENDANT.f90 defines.f90 mesh.f90 \
subdomains.f90 vector.f90 module_fem_extract_complex.f90 module_fem_extract.f90 \
module_fem_extract_real.f90 module_bsearch.f90 module_cells.f90 \
module_dataset_2411.f90 module_dataset_2412.f90 module_dataset_2467.f90 \
module_dataset.f90 module_FE_DB.f90 module_groups.f90 module_mesh.f90 \
module_readUNV.f90 module_unv.f90 module_xml_parser.f90 LIB_VTK_IO.f90 \
LIB_VTK_IO_READ.f90 module_writeVTU.f90 module_conver3d.f90 \
module_conver3d_source.f
# DEPENDENCIAS ENTRE MODULOS
# si pru1 depende de pru2... pru1.o: pru2.o
comprobaciones.obj: mesh.obj modulos_electros3D.obj modulos_electros3D.obj \
modulos_electros3D.obj modulos_electros3D.obj modulos_electros3D.obj \
mod_mcambio.obj: modulos_electros3D.obj
modulos_electros3D.obj:
module_ALLOC_char_r1.obj: module_REPORT.obj
module_ALLOC.obj: module_ALLOC_int_r1.obj module_ALLOC_int_r2.obj \
module_ALLOC_int_alloc_r2.obj module_ALLOC_real_r1.obj module_ALLOC_real_r2.obj \
module_ALLOC_real_alloc_r2.obj module_ALLOC_real_DOUBLE_r1.obj \
module_ALLOC_real_DOUBLE_r2.obj module_ALLOC_char_r1.obj module_ALLOC_log_r2.obj
module_ALLOC_int_alloc_r2.obj: module_ALLOC_int_r1.obj
module_ALLOC_int_r1.obj: module_REPORT.obj
module_ALLOC_int_r2.obj: module_REPORT.obj
module_ALLOC_log_r2.obj: module_REPORT.obj
module_ALLOC_real_alloc_r2.obj: module_ALLOC_real_r1.obj
module_ALLOC_real_DOUBLE_r1.obj: module_COMPILER_DEPENDANT.obj module_REPORT.obj
module_ALLOC_real_DOUBLE_r2.obj: module_COMPILER_DEPENDANT.obj module_REPORT.obj
module_ALLOC_real_r1.obj: module_REPORT.obj
module_ALLOC_real_r2.obj: module_REPORT.obj
module_CONVERS.obj: module_COMPILER_DEPENDANT.obj module_REPORT.obj
module_FILES.obj: module_REPORT.obj module_CONVERS.obj
module_REPORT.obj: module_COMPILER_DEPENDANT.obj module_SO_DEPENDANT.obj
module_SO_DEPENDANT.obj: module_COMPILER_DEPENDANT.obj
defines.obj: module_COMPILER_DEPENDANT.obj
mesh.obj: defines.obj
subdomains.obj: defines.obj
vector.obj: defines.obj
module_fem_extract.obj: module_fem_extract_real.obj \
module_fem_extract_complex.obj
module_dataset_2411.obj: module_COMPILER_DEPENDANT.obj module_ALLOC.obj \
module_dataset.obj module_mesh.obj
module_dataset_2412.obj: module_ALLOC.obj module_dataset.obj module_mesh.obj \
module_FE_DB.obj module_cells.obj
module_dataset_2467.obj: module_dataset.obj module_mesh.obj module_cells.obj \
module_groups.obj
module_dataset.obj: module_REPORT.obj module_CONVERS.obj
module_FE_DB.obj: module_COMPILER_DEPENDANT.obj
module_groups.obj: module_ALLOC.obj
module_mesh.obj: module_COMPILER_DEPENDANT.obj module_ALLOC.obj module_FILES.obj
module_readUNV.obj: module_COMPILER_DEPENDANT.obj module_SO_DEPENDANT.obj \
module_CONVERS.obj module_unv.obj module_mesh.obj
module_unv.obj: module_ALLOC.obj module_FILES.obj module_mesh.obj \
module_dataset_2411.obj module_dataset_2412.obj module_dataset_2467.obj \
module_bsearch.obj
module_xml_parser.obj: module_ALLOC.obj module_CONVERS.obj module_REPORT.obj \
module_FILES.obj
LIB_VTK_IO_READ.obj: LIB_VTK_IO.obj
module_writeVTU.obj: LIB_VTK_IO.obj
module_conver3d.obj: module_COMPILER_DEPENDANT.obj module_conver3d_source.obj
# INCLUDES
includes =
# COMPILER
FC = gfortran
# COMPILER OPTIONS
FFLAGS = -J$(dir_objetos) -ffree-line-length-0 -ffixed-line-length-0
# LINKER OPTIONS
LDFLAGS = -static
# Non-modifiable part
# CARPETAS DE BUSQUEDA
VPATH = $(subst ,:,$(strip $(dir_fuentes)))
vpath %.obj $(dir_objetos)
# FUENTES
fuentes_ = $(filter %.f %.F %.for %.FOR %.f90 %.F90 %.f95 %.F95 %.f03 %.F03,$(shell dir /b $(dir_fuentes)))
fuentes = $(filter-out $(notdir $(condir_principal)) $(modulos),$(fuentes_))
# OBJETOS
modulos_obj = $(addsuffix .obj,$(basename $(modulos)))
fuentes_obj = $(addsuffix .obj,$(basename $(fuentes)))
# OBJETOS EN SU CARPETA
condir_modulos_obj = $(addprefix $(dir_objetos)/,$(modulos_obj))
condir_fuentes_obj = $(addprefix $(dir_objetos)/,$(fuentes_obj))
# OPCIONES DE COMPILACION
FFLAGS += $(patsubst %,-I%,$(dir_fuentes))
FFLAGS += -I$(dir_objetos)
# REGLA PRINCIPAL
all: $(ejecutable)
$(ejecutable): $(includes) $(modulos_obj) $(fuentes_obj)
$(FC) -o $(ejecutable) $(FFLAGS) $(condir_principal) $(condir_modulos_obj) $(condir_fuentes_obj) $(LDFLAGS)
# REGLA PARA LAS FUENTES
$(fuentes_obj): $(includes) $(modulos_obj)
# PATRONES DE REGLAS
%.obj:%.f
$(FC) -c -o $@ $(FFLAGS) $<
@copy $@ $(dir_objetos)
@del $@
%.obj:%.F
@del $@
%.obj:%.for
@del $@
%.obj:%.FOR
@del $@
%.obj:%.f90
@del $@
%.obj:%.F90
@del $@
.PHONY: clean
clean:
del $(dir_objetos)\*.obj
del $(dir_objetos)\*.mod
del $(ejecutable)
