29641 Discussions
error in converted code from compaq visual fortran
milad_m_
hi
my code written  in compaq visual fortran , now i converted to intel visual fortran (in visual studio) from this refrence
https://software.intel.com/en-us/articles/migrating-from-compaq-visual-fortran
so when run it i face this to error that  cant find reason!
errors:
1     error LNK2019: unresolved external symbol _GETTIM@16 referenced in function _MAIN__     TINAK.obj
2     fatal error LNK1120: 1 unresolved externals    Debug/TINAK.exe
What Should I do?
im new ,please clear it!
thanks
with regard
mecej4
A simple fix is to add "USE IFPORT" at the beginning of every subprogram from which a call to GETTIM is made. A better fix is replace calls to the non-standard routine GETTIM with calls to the intrinsic subroutine CPU_TIME or SYSTEM_CLOCK, as appropriate.
It appears that your ported program is still using the stdcall linkage convention. Please consider converting to the default convention in Intel Fortran, which is the CREF (cdecl by reference) convention.
mecej4
milad_m_
wow!
replace GETTIM  with CPU_TIME
work!
for find the solution, i search and read many things for many time in net.
but  " ask a question is the best!  "
thanks
