error lnk2019,error lnk1120
kuan__JIANG
hello guys;
I'm working on an old fortran project which was made on compaq visual Fortran,and now run it on intel visual fortran composer XE2011(32bit) with visual studio2010(32bit);
When I compile the project I have the following errors :
(timstart.obj) : error LNK2019: unresolved external symbol  _ETIME@4,referenced in function _timstart.obj
3>(timstop.obj) : error LNK2001: unresolved external symbol  _ETIME@4
3>(timset.obj) : error LNK2001: unresolved external symbol _ETIME@4
3>(fabend.obj) : error LNK2019: unresolved external symbol  _ABORT@0,referenced in function _fabend.obj
3>Release/Relap.exe : fatal error LNK1120: 2 unresolved externals
please help me
thank u very much.
mecej4
I am glad to hear that you were able to overcome the problems!
mecej4
You are probably specifying the Compaq calling convention (/iface:cvf). In the subprograms from which ETIME and ABORT are called, verify that you have a USE IFPORT statement prior to any declarations.
kuan__JIANG
thank you very much.
I found your answer by this:https://software.intel.com/en-us/forums/intel-fortran-compiler/topic/379279
but i don't know how to verify "that you have a USE IFPORT",could you tell more details
thanks a lot.
mecej4
Are the object files timstart.obj, timstop.obj, timset.obj and fabend.obj compiled from source files in your project, or are they in a library for which you do not have the sources? In your project, have you specified CVF compatibility?
kuan__JIANG
thank u very much.
these timstart.f 、timstop.f、timset.f  files are in my source files and i can edit them,after compile,then generate timstart.obj、timstop.obj etc.
thanks a lot
Linking...
3>Rplib_.lib(gninit.obj) : error LNK2019: unresolved external symbol _GETARG@12,unresolved external symbol _GNINIT
3>Rplib_.lib(gninit.obj) : error LNK2019: unresolved external symbol _IARGC@0,unresolved external symbol _GNINIT
3>Rplib_.lib(timstart.obj) : error LNK2019: unresolved external symbol _ETIME@4,unresolved external symbol _TIMSTART
3>Replib_.lib(timstop.obj) : error LNK2001: unresolved external symbol _ETIME@4
3>Enlib_.lib(timset.obj) : error LNK2001: unresolved external symbol _ETIME@4
3>Enlib_.lib(fabend.obj) : error LNK2019: unresolved external symbol _ABORT@0,unresolved external symbol _FABEND
3>Release/Rlap.exe : fatal error LNK1120: 4 unresolved external symbol
mecej4
In each subprogram within which one or more non-standard subroutines or functions such as ETIME and ABORT are called, insert a USE IFPORT statement immediately after the subroutine/function line. After making these changes, recompile and rebuild.
If you still have problems after you do so, please zip up all the source files and attach the zip file to your reply.
kuan__JIANG
thank u very much
but it didn't work
Enlib\timset.f(80): error #6401: The attributes of this name conflict with those made accessible by a USE statement.   [ETIME]
LINK : fatal error LNK1104: can't open file“dfor.lib”
mecej4
We are making progress.
Please show a few source lines in the neighborhood of the offending line (timset.f90, line 80). If it is a type declaration or an interface to ETIME, remove or comment out the declaration.
kuan__JIANG
thank u very much!!!!!!!!!!!
i delete many statement of etime,abort,getarg,irgc
like :real*4 etime,external etime
after delet them ,it works, thank u very very very much!!!
mecej4
kuan__JIANG
thank u very much!!
