error loading plugin: libimf.so
CAB478
I am running OneAPI 2022.1.2.117 on RHEL 8.6 and receive the following error during compilation.
ifort -o Section_make_poly Section_make_poly.f
ld: /opt/intel/oneapi/compiler/2022.0.2/linux/bin/intel64/../../bin/intel64/../../lib/icx-lto.so: error loading plugin: libimf.so: cannot open shared object file: No such file or directory
Is there anyone with a suggestion?
Ron_Green
either a bad installation or an incomplete LD_LIBRARY_PATH
cd /opt/intel/oneapi/compiler/latest
 find . -name libimf.so
./linux/compiler/lib/ia32_lin/libimf.so
./linux/compiler/lib/intel64_lin/libimf.so
now check
echo $LD_LIBRARY_PATH
check that env var has /opt/intel/oneapi/compiler/2022.0.2/linux/lib/intel64_lin  in the path
You are using bash as shell and
source /opt/intel/onepi/setvars.sh
