errors with openMP
m-yaghoobi
Hi.
I have already used Intel visual Fortran 11 and utilized openMP to parallelize my code.
However,when I use SECTION type (i.e.,!$OMP SECTIONS) and the file size become bigger than a specific value, this sectioncould not bedetected by compiler.It means when the file size is small, compilershow this remark:"openMP DEFINED SECTION WAS PARALLILZED". But with growing file size (with the correct sequential format),programm neglect this SECTION PART.
Is it really a relationship between size and this problem?
Best regards, Mohammadreza
TimP
What does the compiler say about it (e.g. with /Qopenmp-report2) ?
jimdempseyatthecove
You can use either:
!$OMP PARALLEL SECTIONS
!$OMP SECTION
... ! section 1
!$OMP SECTION
... ! section 2
!OMP END PARALLEL SECTIONS
(1st "!$OMP SECTION" is optional)
.or.
!$OMP PARALLEL
!$OMP SECTIONS
!$OMP SECTION
... ! section 1
!$OMP SECTION
... ! section 2
!OMP END SECTIONS
!OMP END PARALLEL
Check to see if your code is blending the two different formats resulting in an unintended nesting of parallel regions (sections).
If you suspect the file size is introducing a compiler error then think about making a subroutine out of the section (then call the subroutine from the section).
Jim Dempsey
anishtain4
Jim can I ask you a question about eclipse and photran? I know intel does not support eclipse yet but I'm trying to use another compiler so I can't make a topic here, but I need help desperately. please let me know on my email if you can spare anytime for me at my email: [email protected]
