29651 Discussions
explicit initialization of derived type parameters; positional vs keyword fields
joseph_battelle
It seems that the current compiler only allows positional fields inside structure constructors when initializing parameters. Variable derived types can be explicitly initialized by structure constructors with named fields as well as positional. See code below for examples. Is this a bug or is this what the standard requires? I haven't found it in the standard (yet).
Compiling with Intel Visual Fortran 11.1.065 [IA-32]...
[fortran]program C4
    type :: m
        integer :: i = 0
    end type
    type :: o
        integer :: id = 0
        type(m) :: cache = m (1)
        logical :: multi = .false.
    end type o
    !OK
    type(o)            :: x1 = o(1, multi=.true., cache = m(5))
    type(o)            :: x2 = o(1, cache=m(5), multi=.true.)
    type(o)            :: x3 = o(1, cache=m(5))
    type(o)            :: x4 = o(1, multi=.true.)
    !error #7747: Invalid parameter expression.
    type(o), parameter :: a1 = o(1, multi=.true., cache = m(5))
    type(o), parameter :: a2 = o(1, multi=.true.)
    !OK relying on default initializers as long as you dont name fields
    type(o), parameter :: a4 = o(1, m())
    type(o), parameter :: a3 = o(1, cache=m())
end program C4[/fortran]
Escalated as issue DPD200157285. Thanks for the nice example.
I know we've had some issues with keywords in structure constructors - I'll take a look at this on Monday.
joseph_battelle
Thanks for looking into this Steve. The standard talks of only one sort of structure constructor and my reading is that all of the above code should be valid.
-joe
joseph_battelle
Any progress on characterizing this?
Not yet -sorry. But I will get to it soon.
This will be fixed in an update, probably the first one, to the next major release.
