Goodevening friends,
i used to build a program with intel fortran. this program uses some fortran files, some c and c++ files.
using cl i compiled the c and c++ programs and transformed them to object files.
using ifort i compiled the fortran programs and transformed them to object files.
using ifort again, i linkedall theobjects into the executable file.
this happened succesfully.
Now i wanted to extend my executable and add some graphical tools using the openGL libraries. I programmed some functions in c++ files which worked fine with other compilers like compiling in the interface of visual studio. but when i tried to compile the same way i used to do, the intel visual fortran compiler gives an error saying that there are unresolved external symbols referred in your program. i guess that the libraries of OPENGL must be added somehow to the link command using ifort. if that is the case, i will be grateful if some one help me to figure out this way. if not, can you show me the way to compile fortran programs andc++ using opengl programs with intel visual fortan like i explained above?
thank you in advance.
For the linker to be able to link (i) your C objects, (ii) your Fortran objects and (iii) the OpenGL libraries, you have to induce the C and Fortran compilers to use a name mangling scheme that is compatible with the names that exist in the OpenGL libraries. Alternatively, to a smoothly functioning project with a set of C objects and libraries you can add Fortran sources using the Fortran 2003 C-interoperability modules.
See this recent thread.
thank you for your answer, but excuse my ignorance, i didn't understand very well what you proposed for me to do. would you please show me the way through a little example using all these components?
All I want, is what to write additionally in the source code and in the compiler instructions for compiling the objects and building the executable.
Thank you in advance.
Intel Visual Fortran provides the module IFOPNGL which declares OpenGL routines, types and constants. Add:
USE IFOPNGL
to get access to these. Note that the names of functions are preceded with "f" and types may have _T added to their names. You should take a look at the provided OpenGL sample programs to get a feel for how it works, and it also helps to read the source for ifopngl.f90 in the compiler's Include directory. Using the module will automatically link in the correct libraries.
USE IFOPNGL
Thank you Steve for your answer, I think i've already tried it but i didn't succeed. So i tried another way. I will try it again and see what will be the result. I ll come back to you when finished.
Thank you again.
Thank you again.
Topic Options
