29381 Discussions
fatal error LNK1104 linking MS C++ with Fortran
bjdesa
I have two files source1.f90 and main.cpp the Fortran file has a subroutine and the cpp file has a program that calls the fortran subroutine
I compiled the fortran file and the built a static library file using the following command line options
ifort source1.f90 /nologo /debug:full /Od /gen-interfaces /warn:interfaces /traceback /check:bounds /libs:static /threads /dbglibs /c
lib /out:lib1.lib source1.obj
But when I compiled the cpp file using
CL main.cpp /link LIB1.LIB
I get the following error
D:\temp>CL main.cpp /EHsc /link LIB1.LIB
Microsoft (R) C/C++ Optimizing Compiler Version 17.00.60610.1 for x64
Copyright (C) Microsoft Corporation.  All rights reserved.
main.cpp
Microsoft (R) Incremental Linker Version 11.00.60610.1
/out:main.exe
LIB1.LIB
main.obj
LINK : fatal error LNK1104: cannot open file 'ifmodintr.lib'
How do I fix this problem so that my program compiles
