With Intel one APi and Visual Studio 19 I try to compile and link the following
simple program:
program addNumbers
! This simple program adds two numbers
implicit none
! Type declarations
real :: a, b, result
! Executable statements
a = 12.0
b = 15.0
result = a + b
print *, 'The total is ', result
end program addNumbers
compiling is without errors but the linker provides:
fatal error LNK1120: 1 nicht aufgelöste Externe
error LNK2019: Verweis auf nicht aufgel”stes externes Symbol "_WinMain@16" in Funktion ""int __cdecl invoke_main(void)" (?invoke_main@@YAHXZ)". MSVCRTD.lib(exe_winmain.obj)
What is still missing ?
It looks as if the link step is trying to build a (32-bits?) DLL instead of a proper standalone program. Can you check the type of project?
You chose the wrong project type. Select Empty Project (with the Console tag) or Main Program Code as the project type.
