29375 Discussions
forrtl: severe (174): SIGSEGV, segmentation fault occurred when I try to run FVCOM code on Linux (colorado) system
Sunnyday
Hello, all
I've faced a problem about :forrtl: severe (174): SIGSEGV, segmentation fault occurred when I try to run FVCOM code on Linux (colorado) system.
Image              PC                Routine            Line        Source
fvcom              0000000000521FAE  Unknown               Unknown  Unknown
fvcom              000000000055B222  Unknown               Unknown  Unknown
fvcom              0000000000766292  Unknown               Unknown  Unknown
fvcom              000000000069FDB8  Unknown               Unknown  Unknown
fvcom              000000000073C0AA  Unknown               Unknown  Unknown
fvcom              0000000000444E1C  Unknown               Unknown  Unknown
libc.so.6          00002AAF4D792994  Unknown               Unknown  Unknown
fvcom              0000000000444D29  Unknown               Unknown  Unknown
I want to use -heap-arrays as recommended, however, I'm not sure if I used the right format of it.
-bash-3.2$ ifort -heap-arrays 10 fvcom
fvcom:(.rodata+0x0): multiple definition of `_IO_stdin_used'
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crt1.o:(.rodata.cst4+0x0): first defined here
fvcom: In function `main':
(.text+0xe0): multiple definition of `main'
/curc/tools/nonfree/redhat_5_x86_64/ics_2011.0.013/composerxe-2011.0.084/compiler/lib/intel64/for_main.o:/export/users/nbtester/efi2linux_nightly/branch-12_0/20101007_000000/libdev/frtl/src/libfor/for_main.c:(.text+0x0): first defined here
fvcom: In function `_fini':
(.fini+0x0): multiple definition of `_fini'
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crti.o:(.fini+0x0): first defined here
fvcom: In function `_start':
(.text+0x0): multiple definition of `_start'
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crt1.o:(.text+0x0): first defined here
fvcom: In function `_init':
(.init+0x0): multiple definition of `_init'
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crti.o:(.init+0x0): first defined here
fvcom: In function `__data_start':
(.data+0x0): multiple definition of `__data_start'
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crt1.o:(.data+0x0): first defined here
Any suggestion to solve this problem?
Qianru
TimP
Are you hoping to use ifort to reconfigure an executable without a full rebuild?  That doesn't work.  You must rebuild each procedure you want to switch e.g. ifort -c -heap-arrays *.f and re-link from object files and libraries.
You probably want heap-arrays with no size specifier, which will make all alllocations on heap.  The size specifier keeps all allocations of size which is not known at compile time on stack.
Adding the -traceback option to the link step may help in finding where a segv occurs by running under debugger.   Such hints should be included in the paper on resolving segv which should be referred to in "useful information..." at the top of the forum.
By the way, you posted in the Windows forum; there is a separate one for linux.
Moved to the Linux forum
