fortran 11.1 spr - bug report
John_David
Theattached code fails to compile correctly under 11.1 but does compile correctly under 8.2
This program is not legal Fortran. The computed GOTO branches into the middle of IF-THEN blocks, which is prohibited and can lead to unexpected results. The compiler does warn you about this.
