I ported fortran code from fortran power station(4.0) to fortran 11(2003) version. For maintaining double/real values from old to new compiler, I changed properties>fortran>data>"Default Read Kind" from 4 to 8. Now the problem is that the global variables are not maintaing data from one file to other.
Suppose, I created a real*8 variable(ex:abc) in one file as a global(COMMON/test/abc), it is modifying in one file and using it in other file, while coming to other file"abc" variable is not holding the modified data. This is happening only when I changed "Default Real Kind" to 8. Is there any other options I need to modify from properties window?
Please give a solution. Thanks in advance.
Can you create an example program and attach it to this thread?
There could be many reasons: If variables are declared REAL*4 for example, the compiler option will have no effect. Only variables like this:
REAL x,y,z
would be affected. the '*4' overrides your compiler option.
ron
