28386 Discussions
fortran allocation, unknown a priori DIMENSION
mic_esp96
I want to generalise allocation of a variable which may have different number of dimension.
To do so I created an interface having different procedures which are called depending of the SIZE of DIMS (the array of the dimensions).
To be clearer:
inteface allbisp
    module procedure allbisp1
    module procedure allbisp2
    module procedure allbisp3
end interface allbisp
in which  subroutine allbisp"i"(bisp, dims, varname)  the difference stands in dims("i") only. Depending the case, bisp has different number of dimensions.
Moreover, in the case allbisp2 (i.e. in which dims is array with 2 values) I would like to differentiate w.r.t. the value 1 of dims.
That is, IF (dims(1).eq.SPEC_VALUE) then "allocate bisp with 5 dimensions" ELSE "allocate bisp with 4 dimensions" END IF
However, this requires to know a priori dims(1) and then the number of dimensions of bisp to correctly declarate it, which is the opposite of using interfaces to generalise things.
I hope I was clear enough.
Michele
Arjen_Markus
Honored Contributor I
Well, interfaces distinguish on the basis of the type, rank and kind of their arguments. So, distinguishing based a value of one of the arguments is impossible. But the kind of things you want to do could be done via an assumed-rank array. I have never used them, but they are implemented in Intel Fortran 19 (https://software.intel.com/content/www/us/en/develop/documentation/fortran-compiler-developer-guide-and-reference/top/language-reference/specification-statements/type-declarations/declarations-for-arrays/assumed-rank-specifications.html).
If this does not help, you may want to redesign the interface - if you pass a 4-dimensional array and the first dimension has the wrong value, that could be flagged via a run-time error.
mic_esp96
if I declare
real,allocatable,dimension(..) :: bisp
I get: error #6792: The rank of the allocate-shape-spec-list differs from the rank of the allocate-object.
Arjen_Markus
Can you show the full example? I just tried with gfortran (I do not have  access to Intel Fortran 19 at the moment, so couldn't try that), but that works fine:
! assumed_rank.f90 --
!     Test assumed rank arrays
module assumed_rank
    implicit none
contains
subroutine alloc( r )
    real, dimension(..), allocatable, intent(out) :: r
    select rank ( r )
        rank( 1 )
            allocate(  r(100) )
        rank ( 2 )
            allocate(  r(10,10) )
    end select
end subroutine alloc
end module assumed_rank
program test_rank
    use assumed_rank
    real, dimension(:,:), allocatable :: x
    call alloc( x )
    write(*,*) size(x), shape(x)
end program test_rank
mic_esp96
@Arjen_Markus I guess what you did is not what I would like to do. Here it is the code:
interface allbisp
end interface
subroutine allbisp2(bisp,dims,varname)
      implicit none
      !input
      integer,intent(in)::dims(2)
      real,allocatable,dimension(..),intent(inout)::bisp
      character(len=*),optional,intent(in)::varname
      !local
      integer:: istat,dim1,dim2
      if (dims(1).eq.numfrqs) then
         dim1 = dims(1)
         dim2 = dims(2)
         allocate(bisp(dim1,dim1,dim2,dim2,dim2), stat=istat)
         if (istat.ne.0) call errall('ALLBISP2',istat,trim(varname))
      else
         dim1 = dims(1)
         dim2 = dims(2)
         allocate(bisp(dim1,dim1,dim1,dim2), stat=istat)
      end if
end subroutine allbisp2
Then, within the main program one will have:
!declaration
real,allocatable,dimension(..) :: B
real :: dimensions(2)
dimensions = [dim1, dim2]
call allbisp(B, dimensions, 'B') !will get to allbisp2 since size(dimensions).eq.2
mic_esp96
Unfortunately I cannot report the full example since it is part of a large code, but the idea should be explained by previous message. If not clear, I can go deeper, maybe trying to build a quick and simple little program.
mic_esp96
Basically, in your example, in your main you already know the rank of your array. In my example, the rank depends on what the program selects for dimensions.
Arjen_Markus
True, the only thing I can think of that would work is that you pass the array as an assumed-size array (in the FORTRAN 77 tradition) and pass it on as either a 4- or a 5-dimensional array. Though I think that would be rather error-prone.
Assumed-rank arrays are very limited in their use and what you want is in fact a dynamic rank. Fortran does not have that, though there are several techniques I can think of to mimick that. None very elegant though. Can you indeed create a small program that illustrates what you want to do? And can you explain why you want such a dynamic rank? Not how, but why, as we might be able to advise on alternatives.
mic_esp96
Here's a sample program:
subroutine allbisp2(b,dims,val)
   implicit none
   integer,intent(in) :: dims(2),val
   !local
   integer :: dim1,dim2,istat
   if (dims(1).eq.val) then
      dim1 = dims(1)
      dim2 = dims(2)
      allocate(b(dim1,dim1,dim2,dim2,dim2),stat=istat)
      if (istat.ne.0) write(*,'(/,a,/)'), '[ERROR] Error allocating "b"!'
   else
      dim1 = dims(1)
      dim2 = dims(2)
      allocate(b(dim1,dim1,dim1,dim2),stat=istat)
   end if
program main_prog
   implicit none
   integer,dimension(2) :: dims
   integer :: val
   dims = [10,20]
   val  = 10
   call allbisp2(b,dims,val)
   write(*,'(/,/,a)'), '[FINISH] Program ended!'
end program main_prog
The reason:
b is basically a tensor of multiple dimensions (6 or more), the first two representing a surface (3D plot), the others indexes along which iterating. The distinction is to chose whether
  1. to store the entire surface (to be then plotted) for some indexes (I do not explain them since is out if scope)  (CASE 1, true IF)
  2. store a single value of the matrix for some others given values of indexes.
Hope being clear enough.
jimdempseyatthecove
I suggest you .NOT. use assumed rank programming, except for not having any other choice.
Instead consider declaring your array(s) with your model's maximum number of dimensions. Then allocate the desired ranks to their specific sizes and the undesired ranks to size of 1. This will simplify your programming efforts.
Jim Dempsey
mic_esp96
Thanks @jimdempseyatthecove , I knew that possibility, but I was wondering if there was a nicer one, so I asked.
FortranFan
@mic_esp96 ,
With Fortran, the bottom-line is RANKs of your objects need to be known at compile-time.
The advice by @jimdempseyatthecove is very pertinent, especially in terms of compute efficiency.
And also because there is another facility which Fortran allows: the target of a RANK-N array pointer can be a RANK-1 array.
Thus an option you can consider is to make your primary data object 'b' a RANK-1 array and give it the TARGET attribute.
You can then have in your code some 'work' arrays with POINTER attributes.  Say two or more RANK-N and RANK-N+1 arrays of POINTERs e.g., rank-4 and rank-5 as you show with allbisp2 case in your original post.
Then, at run-time based on program logic, can point these work arrays to your base data object 'b' with suitable array bounds.
With this approach, you would then only do allocation and deallocation with object 'b'.  And with your working array pointers, you only associate them in a pointer assignment (=>)and nullify the associations when done.  Thus it can be reasonably safe.
jimdempseyatthecove
TARGET and ASSIGN may be suitable in some places, but in other cases you could pass the  front-slice of the array (the used dimensions), and thus the DUMMY of the called procedure is equivalent to the pointer assignment (with no data transfer).
It may be handy to write a function that returns the ranks used of the large rank placeholder. Note, the Rank-1 allocation method of FortranFan would not provide a means to reconstitute the shape&size of the original array (sans extra dimensions) without having extra scalars assigned and manipulated for this purpose. In the excess dimensions method these "extra scalars" are maintained in the array descriptor.
Jim Dempsey
mic_esp96
Dear @jimdempseyatthecove , could you be more explicit if that does not bother you, I'm not so expert in FORTRAN programming..
What is a "front-slice" of an array? What do you mean in the first sentence of the second paragraph?
Thanks a lot for your comprehension and kindness.
Michele
jimdempseyatthecove
Not specific to your problem, but "front-slice" of an array in general:
real :: array(12,34,56)
call foo(array(:,:,1)) ! same as array(1:12,1:34,1) or 1/56th of array at front part
subroutine foo(frontSlice)
real :: frontSlice(12,34) ! or frontSlice(:,:)
In your case, the "unused" dimensions would have size of 1
real, allocatable :: array(:,:,:,:,:)
allocate(array(12,34,56,1,1) ! 3D array held in 5D descriptor
call foo(array(:,:,:,1,1)) ! pass "front part" to subroutine expecting 3D array
Jim Dempsey
mic_esp96
Thanks @FortranFan . So if I well understood, based on the original sample I reported, I should declare:
real, allocatable, dimension(:), target :: b
real, allocatable, pointer :: ptr4(:,:,:,:), ptr5(:,:,:,:,:)
if (dims(1).eq.GIVEN_VALUE) then
    allocate(ptr5(dim1,dim2,dim3,dim4,dim5))
    ptr5 => b
else
    allocate (ptr4(dim1,dim2,dim3,dim4))
    ptr4 => b
end if
Not sure if I got how to handle the output "b", what I'm interested in finally...
Thanks for your clarification!
jimdempseyatthecove
FF will likely respond. I think he meant something along the line of:
real, pointer :: ptr4(:,:,:,:), ptr5(:,:,:,:,:)
allocate(b(dim1*dim2*dim3*dim4*dim5))
ptr5 => b(dim1,dim2,dim3,dim4,dim5)
else
ptr4 => b(dim1,dim2,dim3,dim4)
end if
Moderator </> (paste code) no longer has Fortran as markup *****
Jim Dempsey
mic_esp96
Thanks @jimdempseyatthecove .
What about:
else
allocate(b(dim1*dim2*dim3*dim4))
end if
But I have a question: with pointer association, does b change shape?? (to 1 to 4/5 dimensions?)
jimdempseyatthecove
b never changes shape. It is Rank-1 of size of allocation.
ptr4, and ptr5 become Rank-4 and Rank-5 pointers to the contiguous allocation made for b. It is your responsibility not to exceed the total size of the allocation of b .AND. to nullify/fix these pointers should you deallocate or reallocate or movealloc b.
Jim Dempsey
FortranFan
Pointer assignment ( ptrN => b ) will have no impact on the shape of 'b' which remains a rank-1 array object.  Subsequent ordinary assignments ( ptrN(n,m,o,p) = x ) can redefine the value of elements of array b, that's all.
Re: your question on syntax, take a look at this example for an illustration:
module m
   real, allocatable, save, target, private :: b(:) ! base data 'held' by module; can be private
   real, pointer, save, public :: ptr4( :, :, :, : ) => null()
   real, pointer, save, public :: ptr5( :, :, :, :, : ) => null()
contains
   subroutine allbisp2(dims,val)
      !Argument list
      integer, intent(in) :: dims(2)
      integer, intent(in) :: val
      if ( dims(1) == val ) then
         ! Checks elided for when 'b' might be allocated already
         allocate( b(dims(1)*dims(2)*dims(1)*dims(2)*dims(1)) )
         ptr5(1:dims(1),1:dims(2),1:dims(1),1:dims(2),1:dims(1)) => b
         print *, "shape of ptr5 = ", shape(ptr5)
      else
         allocate( b(dims(1)*dims(2)*dims(1)*dims(2)) )
         ptr4(1:dims(1),1:dims(2),1:dims(1),1:dims(2)) => b
         print *, "shape of ptr4 = ", shape(ptr4)
      end if
      return
   subroutine clean()
      ! Nullify pointers
      ptr4 => null()
      ptr5 => null()
   end subroutine
end module
program main_prog
   use m
   implicit none
   integer :: val
   dims = [10,20]
   val  = 10
   call allbisp2( dims, val )
   ! .. do some work
   ! diassociate the pointers
   call clean()
   write(*,'(/,/,a)') '[FINISH] Program ended!'
Upon execution of above program, the expected output is:
 shape of ptr5 =  10 20 10 20 10
jimdempseyatthecove
A suggestion for using FortranFan's code sample would be to place a call to clean() in the front part of allbisp2 as well as in an added subroutine deallbisp2 to deallocate the blob b.
The pointer method is suitable in a procedure that is passed b and which needs to directly process ptr....
It is not necessary to construct a pointer when it is only used by an immediately following CALL, it these cases you pass the "slice" of the over-ranked array.
Choose the method that works best for you.
Jim Dempsey
