29487 Discussions
fortran error 38 during write to unit 6
jparry68
I am getting this error from a simple line
write(screen, *) where screen is defined as 6
This is a large legacy app thathas been ported fromCVF 6.6c. I am using IVF 11.1.046 and VS 2008SP1.
The fortran projects do use the following assumptions /assume:noold_unit_star /assume:old_logical_ldio which I think were obtained from another thread on redirecting 0,6 to the same console.
Thanks in advance.
jparry68
Quoting - jparry68
Thanks in advance.
I probably should add some more detail here. This piece of code is running as a dll and the actual error message is
forrtl:severe(38): error during write, unit 6, file CONOUT$
The actual open code is
open (unit=6, FILE=trim(logName), ACCESS='APPEND', STATUS='UNKNOWN', SHARED)
thanks again.
Lorri_M_Intel
Do you actually have a console open?
If this is a DLL, that's not true by default. You will have to use the AllocConsole call. I haven't done this in a while, but you do something similar to this code snippet. The interesting parts are in blue.
subroutine mysub()
use ifwin
integer status
status = AllocConsole()
write (*,*) "Hello world!"
FreeConsole()
return
- Lorri
