29381 Discussions
how can I debug the main code with an input file
bao_z_
I am new for Intel Visual Fortran Compiler. I have a Fortran code which include a main code and a input code, the main code can compile to a .exe file and then read the input file to get necessary input number. my question is how can I debug the main code with the input file so that I can see the parameters change.
Lorri_M_Intel
Go to Project->Properties->Debugging
There will be a field with a name something like "Command arguments".
If you run your executable as:
            foo.exe < myinput.txt
put " <  full-directory-spec/myinput.txt"  in that field.
The easiest way to test is then to select "Start without Debugging" and make sure the input file can be found, and *then* start the true debugging process.
               --Lorri
