I need to use the LCONF from the IMSL library to solve an optimization problem. The subroutine that computes the function values contains some input arguments. I do not know how to pass these parameter values when using LCONF.
Because I also want to use MPI or OpenMP, I want to limit the use of modules or common blocks, which may create conflict in the memory. That is, the parameters I want to use in the function varies in the program. When I parallelize the code, each processor should be able to update and use its own parameters in that function.
In the help, FCN is the user-supplied subroutine to evaluate the function to be minimized. The usage is CALL FCN (N, X, F), where
!=====CODE=========
program main
USE LCONF_INT
USE UMACH_INT
INCLUDE 'link_fnl_static.h'
!DEC$ OBJCOMMENT LIB:'libiomp5md.lib'
IMPLICIT NONE
INTEGER NCON, NEQ, NVAR
PARAMETER (NCON=2, NEQ=0, NVAR=3)
INTEGER MAXFCN, NOUT
REAL A(NCON,NVAR), ACC, B(NCON), OBJ, SOL(NVAR), XGUESS(NVAR), XLB(NVAR), XUB(NVAR), X(NVAR)
EXTERNAL FCN
REAL para, F
DATA A/-1.0, 1.0, -2.0, 2.0, -2.0, 2.0/, B/0.0, 72.0/
DATA XLB/3*0.0/, XUB/20.0, 11.0, 42.0/, XGUESS/3*10.0/
DATA ACC/0.0/, MAXFCN/400/
CALL UMACH (2, NOUT)
para = 1.0
X=2.0
CALL FCN (NVAR, X, F, para)
CALL LCONF (FCN, NEQ, A, B, XLB, XUB, SOL, XGUESS=XGUESS, MAXFCN=MAXFCN, ACC=ACC, OBJ=OBJ)
END
SUBROUTINE FCN (N, X, F, para)
INTEGER N
REAL X(*), F, para
F = -(X(1)-para)*X(2)*X(3)
END
N Value of NVAR. (Input)
X Vector of
length
N at
which point
the function is evaluated. (Input)
X should not be
changed by FCN.
F The computed function value at the point X. (Output)
However, the function I want to minimize will be in the following form: CALL FCN(N,X,F,para). where para is a vector of length NP which is also an input for the function.
Can someone let me know what I should do if I want to minimize such kind of functions? A sample code is below which is adapted from the example with just FCN(N,X,F) in the IMSL mannual. I got error messages on this code. Thank you very much.
!=====CODE=========
program main
USE LCONF_INT
USE UMACH_INT
IMPLICIT NONE
EXTERNAL FCN
REAL para, F
para = 1.0
X=2.0
END
INTEGER N
REAL X(*), F, para
END
LCONF doesn't provide a way to supply an extra argument. An approach you can take is to make FCN an CONTAINed function, which gives it access to its host's local variables. Something like this:
[fortran]program main USE LCONF_INT USE UMACH_INT INCLUDE 'link_fnl_static.h' !DEC$ OBJCOMMENT LIB:'libiomp5md.lib' IMPLICIT NONE INTEGER NCON, NEQ, NVAR PARAMETER (NCON=2, NEQ=0, NVAR=3) INTEGER MAXFCN, NOUT REAL A(NCON,NVAR), ACC, B(NCON), OBJ, SOL(NVAR), XGUESS(NVAR), XLB(NVAR), XUB(NVAR), X(NVAR) REAL para, F DATA A/-1.0, 1.0, -2.0, 2.0, -2.0, 2.0/, B/0.0, 72.0/ DATA XLB/3*0.0/, XUB/20.0, 11.0, 42.0/, XGUESS/3*10.0/ DATA ACC/0.0/, MAXFCN/400/ CALL UMACH (2, NOUT) para = 1.0 X=2.0 CALL FCN (NVAR, X, F) CALL LCONF (FCN, NEQ, A, B, XLB, XUB, SOL, XGUESS=XGUESS, MAXFCN=MAXFCN, ACC=ACC, OBJ=OBJ) CONTAINS SUBROUTINE FCN (N, X, F) INTEGER N REAL X(*), F F = -(X(1)-para)*X(2)*X(3) END SUBROUTINE FCN END[/fortran]
You can pass "para" via common block or module.
Sorry I wasn't clear. Because I also want to use MPI or OpenMP, I want to limit the use of modules or common blocks, which may create conflict in the memory. That is, the parameters I want to use in the function varies in the program. When I parallelize the code, each processor should be able to update and use its own parameters in that function. Any further suggestion? Thank you.
Hi Steve,
Thank you very much. Your suggestion is very helpful.
