how to switch off warning clutter from conditional compilation when checking standard
may_ka
Hi
This program:
program test
  !DIR$ if Defined (bla)
  !DIR$ end if
end program test
when compiled with ifort 17.07:
ifort -stand f08 tmp1.f90
yields:
tmp1.f90(2): warning #7025: This directive is not standard F2008.
tmp1.f90(3): warning #7025: This directive is not standard F2008.
  !DIR$ end if
For the example this is a minor problem, but when compiling +100,000 lines of code it can be become very anying when trying to find dangerous standard violations.
Is there any way to switch that off and still check the code for following the standard??
Karl
Lorri_M_Intel
You can add "-diag-disable 7025" which will turn off ONLY the messages about non-standard directives.
                --Lorri
may_ka
Karl
