-i-static not supported
Agnes_B_
I am using Intel Fortran compiler (ifort version 16.0.2) and I want to compile a (monte carlo) code which has the option -i-static in the make file, but I got the error message "ifort: command line remark #10148: option '-i-static' not supported" though the code was used by other colleague earlier without problem (using version 14). Can the version difference cause the problem, if yes what is the proper substitution for the option? or is there some other setting which might be not properly set on my PC? thanks!
TimP
Spelling of that option was changed to -static-intel.  This should appear in ifort -help
Agnes_B_
Thanks! (I tried that and it compiled but the code is not working properly, so probably there is some other problem)
