idb fails in Ubuntu linux
mhadian
i installed Intel Fortran compiler 9 and idb successfully in ubuntu linux. but idb fails to come up with following message: "/opt/intel/idb/9.0/bin/iidb: error while loading shared libraries: libXft.so.1: cannot open shared object file: No such file or directory"
i did not have such a problem in suse.
TimP
The expected location of this library is /usr/X11R6/lib/libXft.so.1 (e.g SuSE 9.2). If you didn't install X window support, that would account for the problem. Did you run ldd on your iidb?
mhadian
i think the x window support is installed by default in ubuntu. this is the result of ldd on iidb in my system:
mohammad@YazdUni:~$ ldd /opt/intel/idb/9.0/bin/iidb
linux-gate.so.1 => (0xffffe000)
libdl.so.2 => /lib/tls/i686/cmov/libdl.so.2 (0xb7f2d000)
libXt.so.6 => /usr/lib/libXt.so.6 (0xb7ede000)
libXrender.so.1 => /usr/lib/libXrender.so.1 (0xb7ed6000)
libXft.so.1 => not found
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0xb7e6c000)
libXext.so.6 => /usr/lib/libXext.so.6 (0xb7e5f000)
libX11.so.6 => /usr/lib/libX11.so.6 (0xb7d9f000)
libm.so.6 => /lib/tls/i686/cmov/libm.so.6 (0xb7d7b000)
libSM.so.6 => /usr/lib/libSM.so.6 (0xb7d74000)
libICE.so.6 => /usr/lib/libICE.so.6 (0xb7d5b000)
libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0xb7c2d000)
/lib/ld-linux.so.2 (0xb7f40000)
libz.so.1 => /usr/lib/libz.so.1 (0xb7c19000)
libXau.so.6 => /usr/lib/libXau.so.6 (0xb7c15000)
libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0xb7c11000)
i have libXft.so.2 in my /usr/lib which is a link to /usr/lib/libXft.so.2.1.2
is it possible that idb use this one instead of libXft.so.1? if yes, how i can do it?
mhadian
i installed the package libxft1 and now the idb works well.
i will appreciate if you let me know how i could use the idb using libxft2 which is installed by default in ubuntu.
Deleted_U_Intel
This is also a problem for me.
supermagnetcn
I have the same problem on Debian testing system. I have libXft2 installed and found that the usage of libXft1 is discouraged. Another problem is that libXft1 is conflicting with my current settings.
metamerik
You might want to try symbolic link:
$ sudo ln -s /usr/lib/libXft.so.2 /usr/lib/libXft.so.1
