idb open failed
Hang_S_
I type the command idb and then it begins to load, but soon as it loaded, it quit automatically. Is it because my hardware is 64 bits? What shall I do?
TimP
idb requires a working java JRE. If you haven't set that up, you might verify that idbc (text display) is working. 32- vs. 64- bitness isn't a question of your hardware. If you run a 32-bit OS, idb must be a 32-bit installation, and the application must be build for 32-bit mode. If a 64-bit OS, 64-bit idb works with both 32- and 64-bit applications (then JRE must be 64-bit).
TimP
Hang_S_
Thank you so much! I ssh to my computer in my office and run idbc, it's ok. I'll go to office tomorrow and check the JRE.
TimP
If you wish to run idb across ssh, ssh -Y should work when the JRE is set up to run on the remote machine.
Hang_S_
I installed openJDK and solved the problem, thank you so much!
