29391 Discussions
if the module has a interface, when i click build solution, it always rebuilds
Li_L_
recently i suffer the problem of rebuilding everything even when i do nothing with my code
i find the interface is one of reasons, an example like this
module inter
    !interface itf
    !    module procedure:: op
    !end interface
contains
    subroutine op
    end subroutine op
end module inter
program main
end program main
if without the interface, clicking <build solution> throws the message 'up to date'
but once the module has an interface, visual studio always rebuild the file when i click <build solution>
is there any way avoiding this situation?
it takes me too much time when debugging my project!
i use psxe2017 updta2 and vs2015
Steve_Lionel
I can reproduce this with your source. A workaround is to remove the "module" keyword from "module procedure" (it is optional in this context.) Looks like a bug in the build system's dependency analyzer.
Steve_Lionel
Steve_Lionel
Li_L_
thanks for your suggestion, it works in this context
but the rebuilding still exists in my project after modification.
i can't find another reason for now
if i find it, i will let you know
Kevin_D_Intel
I also can reproduce this and reported it to Development. I informed them the work around Steve found is only helpful within the small reproducer context and requested help with finding any other possible work around. If you wan to post another reproducer for which the work around is not helpful I will gladly pass that along to Development too.  Thank you for the convenient reproducer also.
(Internal tracking id: DPD200419360)
Li_L_
when i restart vs, the rebuild disappear
Li_L_
and i want know what's the difference between the <module procedure> and <procedure>
jimdempseyatthecove
In a module, contained subroutines and functions do not require an interface.
In your example case, your "interface" is simply a redeclaration for a subroutine. In your actual program,  you may have multiple different subroutines (i.e. as for generic interface), or you simply wish to rename the interface.
Try placing into a separate module (and compilation unit) and use the only and => to remap the names. You may also need to specify a dependency in the solution such that the contains module is built first. IOW this may require your solution to have (at least) 3 projects:
1) contains module project (also holding general data)
2) interface module project (dependent upon the contains module)
3) application project (dependent on interface module project)
Jim Dempsey
Steve_Lionel
In Fortran 90, the "module" keyword was required when declaring a module procedure for a generic interface. Fortran 2003 made that keyword optional. There is no difference here.
The "module" keyword is required if you are declaring an interface for a separate module procedure that is supplied in a submodule.
Li_L_
got it! thanks!
Li_L_
Jim Dempsey
the description of my title is not accurate
it's not the interface leading to build problem, but the difference of <module procedure> and <procedure>
still thanks for your help
jimdempseyatthecove
Run a simple experiment:
a) Edit the contains section (this can be as simple as adding a comment)
b) Build
Next, click on Build again. If it rebuilds, then the work around I offered in #8 will prevent the unnecessary build. The suggestion I made was to break the circular dependency (that should not have been there).
If the rebuild did not occur then the removal of the optional "module" keyword is all you have to do (for now).
Jim Dempsey
