In ifort version 19.0.3, a defined assignment of an object seems to be broken. An assignment of the sort "b(i) = a(i)" seems to be behaving like "b(i) = a(1)". An explicit call to the subroutine works, though.
The following code:
MODULE test_mod IMPLICIT NONE TYPE obj Integer :: i CONTAINS PROCEDURE :: assign => assign_obj GENERIC :: ASSIGNMENT(=) => assign END TYPE obj ! Replacing the Type-Bound Procedure by the following interface leads to the same results ! INTERFACE ASSIGNMENT(=) ! PROCEDURE assign_obj ! END INTERFACE CONTAINS SUBROUTINE assign_obj(this, src) IMPLICIT NONE CLASS(obj), INTENT(INOUT) :: this CLASS(obj), INTENT(IN) :: src print *, src%i this%i = src%i END SUBROUTINE assign_obj end module test_mod program test use test_mod implicit none CLASS(obj), DIMENSION(:), ALLOCATABLE :: a, b Integer :: i, N N = 5 ALLOCATE( a(N), b(N) ) do i=1, N a(i)%i = i enddo do i=1, N ! The following assigment should do the same as each of the other two commented out ! lines below that, but ifort 19.0.3 seems to be doing somethin like "b(i) = a(1)" b(i) = a(i) ! call b(i)%assign( a(i) ) ! call assign_obj( b(i), a(i) ) enddo print*, "test" do i=1, N print*, b(i)%i enddo end program
After compilation with ifort 17.0.1, ifort 18.0.2, gfortran 6.3.0 , gfortran 7.3.0and pgfortran 18.4-0 and execution produces, as expected:
1
2
3
4
5
test
1
2
3
4
5
After compilation with ifort 19.0.3 and execution produces
1
1
1
1
1
test
1
1
1
1
1
Notably, replacing "b(i) = a(i)" by "call b(i)%assign( a(i) )" or "call assign_obj( b(i), a(i) )" works as expected.
I believe I'm working within the specifications of this, this and this. So it seems to me like a compile bug. What do you think?
Hi Jonas,
very interesting piece of code. Your assigment is _not_ defined elemental, and you also don't apply it to an array of types obj, but only elementwise. However, defining your assigment as elemental subroutine (and removing the print statement within) is a workaround that also makes ifort 19 produce the desired result. To me this looks indeed like a bug in ifort v19, and you might want to report this in the Intel Support Center to check with them. gfortran, nagfor, pgi and older versions of ifort produce the desired result.
Cheers,
J
Juergen R. wrote:.. you might want to report this in the Intel Support Center ..
@Schwab, Jonas:
As suggested above, it will be very useful to Intel Fortran users if you can submit your nice case in the original post as a support request with Intel. Defined assignments with polymorphic objects is a very valuable feature in the Fortran standard and it's very important the Intel Fortran compiler gets this right.
In addition to when the defined assignment is marked ELEMENTAL, the results are as expected with Intel 19.0.3 also when the second argument (the RHS) in the bound procedure for assignment is not polymorphic (type(obj) vs class(obj)) and when the objects in your test main are not polymorphic (type(obj), .. :: a, b).
So one should expect the Intel compiler team to be keen to look at this likely regression in update 3 of their product.
For more complete information about compiler optimizations, see our Optimization Notice.
