29386 Discussions
ifort (2021.2.0) compiling error for cosmoMC
CoryChu
I got the error when I tried to compile the cosmoMC (https://github.com/cmbant/CosmoMC)
It can be done by gfortran without any problem.
My intel-oneAPI was installed via apt-get on Ubuntu 20.04.1
mpiifort -fc=ifort -mkl -O3 -no-prec-div -fpp -qopenmp -xHost -DMPI -I../camb/fortran/ReleaseMPI -I/home/ccc/prog/cosmos/intel-CosmoMC/source/../camb/forutils/ReleaseMPI/  -module ReleaseMPI -IReleaseMPI/ -c calclike.f90 -o ReleaseMPI/calclike.o
mpiifort -fc=ifort -mkl -O3 -no-prec-div -fpp -qopenmp -xHost -DMPI -I../camb/fortran/ReleaseMPI -I/home/ccc/prog/cosmos/intel-CosmoMC/source/../camb/forutils/ReleaseMPI/  -module ReleaseMPI -IReleaseMPI/ -c ImportanceSampling.f90 -o ReleaseMPI/ImportanceSampling.o
ifort: error #10105: /opt/intel/oneapi/compiler/2021.2.0/linux/bin/intel64/../../bin/intel64/fortcom: core dumped
ifort: warning #10102: unknown signal(0)
ifort: error #10106: Fatal error in /opt/intel/oneapi/compiler/2021.2.0/linux/bin/intel64/../../bin/intel64/fortcom, terminated by unknown
compilation aborted for ImportanceSampling.f90 (code 1)
make[1]: *** [Makefile:290: ReleaseMPI/ImportanceSampling.o] Error 1
make[1]: Leaving directory '/home/ccc/prog/cosmos/intel-CosmoMC/source'
make: *** [Makefile:17: cosmomc] Error 2
Steve_Lionel
That's an internal compiler error - you'll have to report it to Intel and include sources for reproducing it.
CoryChu
Thanks for your comment.
I thought this is the place I could report to Intel, but I might be wrong. Could you kindly remind me how to report it to Intel? The source is in the Github link.
Barbara_P_Intel
If you haven't paid for support to use the oneAPI software, i.e. you're using the free version, this is the place to report issues.
Please attach the file that is reporting the error and any other files that one depends on. And the compiler options you used. A minimal reproducer is needed.
CoryChu
Thanks!
The source is attached here. I also include the output of my make command in the file "make_ifort_error.log"
Barbara_P_Intel
Are you sure ALL these files are required to reproduce the issue?  There are 53 source files, ~26000 lines of code!
Please attach the minimum number of files required to reproduce the issue.
P.S.  I just found another 60 source files.
CoryChu
Sorry!
Is this one better?
CoryChu
Also, I found that the error only happened if I use the -xHost flag. My CPU is AMD Ryzen 9 5900X. I hope that this information is useful
Barbara_P_Intel
Good find!  -xHost should work for non-Intel processors.  For Ryzen, -march=core-avx2 would be the equivalent.
