29559 Discussions
ifort bug: large array inside BLOCK causes segementation fault
hsnyder
The following program causes a segmentation fault. If I reduce the size of the array `a` dramatically, it runs correctly - perhaps arrays created inside BLOCKs are being put on the stack? I believe this is a bug, but please let me know if I've misunderstood something.
program bug
block
real :: a(86400000)
a=10
print *, a(1)
end block
end program
I'm on Linux (Ubuntu 20.04, kernel 5.11.0-27-generic)
$ ifort --version
ifort (IFORT) 2021.3.0 20210609
Steve_Lionel
It's not a bug. A segfault is Linux' way of saying stack overflow. I am not sure if you can get a stack that big on Linux. Note that Linux does "lazy allocation" so it may not actually allocate the virtual memory until you touch it.
Steve_Lionel
Yes, it's being put on the stack, and you're getting a stack overflow. I suggest making it ALLOCATABLE instead and allocating it to the desired size.
hsnyder
Thanks @Steve_Lionel - I've done as you suggest and it works. I still think it's a bug though - let's see if an Intel employee picks it up and reports it to the developers (I don't have a support subscription yet).
Steve_Lionel
Barbara_P_Intel
unlimit -all prints the default stack size on Linux as
stack size (kbytes, -s) 8192
That can be increased with ulimit -s <some number>.
hsnyder
Right, I understand the segmentation fault, I was just confused about whether or not putting those arrays on the stack was "correct" (it felt surprising). If I understand @Steve_Lionel, then putting arrays declared in a block on the stack doesn't violate anything in the standard. In that case, I'll mark this topic as resolved - thanks very much for clarifying.
Steve_Lionel
It's correct in two ways. First, variables declared in a block have a "scope" limited to that block. so when exiting the block the variable goes away. The stack is a natural way to do this. Second, in Fortran 2018 all procedures are recursive by default. Admittedly you just had a main program, but the overall default for local variables will be on the stack. (Earlier versions of Intel Fortran would default to static allocation for local arrays - but even so, an array in a block is not static.
hsnyder
Ahhh, that makes sense, thanks very much for explaining.
Ron_Green
ulimit -s unlimited
Investigate linux shell limits, particularly stacksize
[rwgreen@orcsle127 u1310894]$ ifort -O0 -o stack stack.f90
[rwgreen@orcsle127 u1310894]$ ./stack
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image              PC                Routine            Line        Source
stack              0000000000403A8A  Unknown               Unknown  Unknown
libpthread-2.28.s  00007FAC1BB23DC0  Unknown               Unknown  Unknown
stack              0000000000402B0B  Unknown               Unknown  Unknown
stack              0000000000402AE2  Unknown               Unknown  Unknown
libc-2.28.so       00007FAC1B771873  __libc_start_main     Unknown  Unknown
stack              00000000004029EE  Unknown               Unknown  Unknown
[rwgreen@orcsle127 u1310894]$ ulimit -a
core file size          (blocks, -c) unlimited
data seg size           (kbytes, -d) unlimited
scheduling priority             (-e) 0
file size               (blocks, -f) unlimited
pending signals                 (-i) 30179
max locked memory       (kbytes, -l) 16384
max memory size         (kbytes, -m) unlimited
open files                      (-n) 1024
pipe size            (512 bytes, -p) 8
POSIX message queues     (bytes, -q) 819200
real-time priority              (-r) 0
cpu time               (seconds, -t) unlimited
max user processes              (-u) 30179
virtual memory          (kbytes, -v) unlimited
file locks                      (-x) unlimited
[rwgreen@orcsle127 u1310894]$ ulimit -s unlimited
   10.00000
