29383 Discussions
ifort bug with some fortran elemental functions
boillod-cerneux__fra
One of my customer has been experiencing a strange bug with ifort compiler.
We've found a workaround as this bug has a minor impact.
Problem Description:
ifort fails to compile the following sample program:
ibset.F90
MODULE IOSTREAM
SAVE
CONTAINS
SUBROUTINE SETUP_IOREQUEST(IBSET)
IMPLICIT NONE
INTEGER,POINTER :: IBSET(:)
END SUBROUTINE SETUP_IOREQUEST
END MODULE IOSTREAM
PROGRAM HOP
USE IOSTREAM, ONLY: SETUP_IOREQUEST
IMPLICIT NONE
INTEGER :: NSTTYP
INTEGER :: TOTO
INTEGER :: IRETRTYPE
ASSOCIATE(NSTTYP=>TOTO)
IRETRTYPE=IBSET(IRETRTYPE,19)
END ASSOCIATE
END PROGRAM HOP
the error is the following one:
ibset.F90(29): error #6410: This name has not been declared as an array or a function.   [IBSET]
compilation aborted for ibset.F90 (code 1)
It happens with ifort compilers :
ifort version 13.0.1
ifort version 15.0.0
ifort version 15.0.1
ifort version 15.0.2
ifort version 15.0.3
ifort version 15.0.4
ifort version 15.0.6
ifort version 16.0.0
ifort version 16.0.1
ifort version 16.0.2
ifort version 16.0.3
ifort version 16.0.4
ifort version 17.0.0
ifort version 17.0.1
The error is raised for all IBSET derivative functions such as:
Name        Argument    Return type    Standard
IBSET(A)    INTEGER A    INTEGER        Fortran 95 and later
BBSET(A)    INTEGER(1) A    INTEGER(1)    GNU extension
IIBSET(A)    INTEGER(2) A    INTEGER(2)    GNU extension
JIBSET(A)    INTEGER(4) A    INTEGER(4)    GNU extension
KIBSET(A)    INTEGER(8) A    INTEGER(8)    GNU extension
The error is not raised when using fortran elemental functions such as SIN, COS...
It seems to be an old bug (with very minor impact) with ifort compiler.
Sincerely
France
Kevin_D_Intel
Thank you. I can reproduce this. There was a similar older report (not within an ASSOCIATE block) with sin() that was fixed. I reported this to Development.
(Internal tracking id: DPD200416582)
