ifort bug
machida
I found that the output depends on optimization options if I compile the following code by ifort.
implicit none
integer i,j,k
do j=1,2
do i=1,2
write (*,*) j
do k=1,2
enddo
enddo
enddo
end
Obviously the correct output is "1 1 2 2". With the default option (-O2), however, the output "2 2 2 2" is obtained. Other options (-O1 or -O0) give the correct result.
The code was run on Itanium 2. The above-mentioned error occurs with ifort 9.1 or higher, though the code runs correctly with ifort 8.1.
This sounds vaguely familiar. Have you tried it with 10.1? If it still does this for you with 10.1, please report it to Intel Premier Support.
Ron_Green
Looks like it's in 10.1.006. Please file a bug report at http://premier.intel.com.
Only affects IA64
ron
Ron_Green
correction: the bug is in 10.1.008, the latest IA64 compiler. File a bug report please.
ron
