ifort: command line warning #10122:
dnoack
I use ifort 11.1.072 with the following comman line:
ifort -D__EFL -DNOSTDCALL -DARGTRAIL -O3 -DPCWIN64_SYS -DPCWINX64_SYS -DPCWINNT_SYS -DCADOE_ANSYS -Qfpp -nbs -4Yportlib -4Ya /c /Fo.\ /DFORTRAN /MD /W0 /object:"..\objects"\ /module:"..\modules"\ /include:%I
and I get the following warning for every source file:
ifort: command line warning #10122: overriding '/object.\' with '/object..\objects\'
I want to get rid of the warning messages.
Please can anyone explain to me, what is wrong in the ifort commant.
Dieter
dnoack
I have solved my problem by myself. The reason for the warning message is, that the options /Fo.\ and /object:"..\objects"\ do the same using different directories and therefore the second option overwrite the first option.
