29389 Discussions
ifort compile-time error: using atomic subroutines with a coarray component within an extented type
Michael_S_17
I did just file a ticket via the Intel Online Service Center at https://supporttickets.intel.com/ for this:
program Main
! ifort compile-time error when using atomic subroutines with a coarray component within an extented type
! OS: Linux Ubuntu 18.04.5 LTS
! compiler: ifort version 2021.1 Beta (usage: command line)
! installed through Intel oneAPI beta version:
! - l_BaseKit_b_2021.1.8.1970_offline
! - l_HPCKit_b_2021.1.8.1883_offline
! compile: ifort -diag-disable 5462 -coarray -coarray-num-images=5 Testing_extends_with_atomic_define.f90 -o a.out
end program Main
module clsSyncBase
use, intrinsic :: iso_fortran_env, only: atomic_int_kind
implicit none
private
type, abstract, public :: objSyncBase
  private
  integer(atomic_int_kind), public, codimension[:], allocatable :: m_atomic_intSyncBase_CC
contains
  private
end type objSyncBase
contains
end module clsSyncBase
module clsEventScalarSync
use clsSyncBase
implicit none
private
!type, abstract, public :: objEventScalarSync !this works
type, extends(objSyncBase), abstract, public :: objEventScalarSync !extends is the first cause of the compile-time error
  private
  integer(atomic_int_kind), public, codimension[:], dimension (:), allocatable :: mA_atomic_intEventSyncStatus_CC
contains
  private
  procedure, public :: Set_atomic_intEventSyncStatus_CC => Set_atomic_intEventSyncStatus_CC
end type objEventScalarSync
contains
subroutine Set_atomic_intEventSyncStatus_CC (Object)
  class (objEventScalarSync), intent (inout) :: Object
      call atomic_define (Object % mA_atomic_intEventSyncStatus_CC(1) [this_image()], 123) !second cause of the compile-time error
end subroutine Set_atomic_intEventSyncStatus_CC
end module clsEventScalarSync
Michael_S_17
This error occurs when calling an atomic subroutine with a coarray component of an extented type. Without the EXTENDS keyword no error occurs.
Maybe I should add the compile time error messages:
Testing_extends_with_atomic_define.f90(49): error #6460: This is not a component name that is defined in the encompassing structure. [MA_ATOMIC_INTEVENTSYNCSTATUS_CC]
Testing_extends_with_atomic_define.f90(49): error #8363: An entity is not a coarray.
Testing_extends_with_atomic_define.f90(49): error #6158: The structure-name is invalid or is missing. [OBJECT]
Testing_extends_with_atomic_define.f90(49): error #6362: The data types of the argument(s) are invalid. [ATOMIC_DEFINE]
Testing_extends_with_atomic_define.f90(49): error #8583: ATOM argument of ATOMIC intrinsic subroutines must be a coarray.
compilation aborted for Testing_extends_with_atomic_define.f90 (code 1)
Michael_S_17
The ticket has already been closed because I don't have a supported product associated with my account. Thus, I think the post here is the best way to submit this issue from my Beta-testing with ifort?
cheers
Michael_S_17
Ok, I did use the beta08 for my testing but meanwhile the beta09 is out. So I will check this again with the new beta09.
cheers
Michael_S_17
I did just test with the latest beta09 installed, l_BaseKit_b_2021.1.9.2195_offline and l_HPCKit_b_2021.1.9.2205_offline. Ifort version is still 2021.1 Beta: The compile time errors remain.
The code compiles if I don't use EXTENDS or without the call to ATOMIC_DEFINE. It's certainly a bug.
Ron_Green
Ron_Green
Bug ID is CMPLRIL0-33285
