ifort compiler
saradiruzza
I have a Mac and after updating macOs Big Sur 11.2.3 I cannot compile any more. The error give me is:
ld: library not found for -lSystem
I tried to link to the library but I can not be able to solve the problem. Moreover, I tried to install again the intel compile but equally, I could not compile.
Just before the update I compiled my program by:
ifort threeBP_D.f90 routine_D.f90 -o threeBP_D
just after the update od macOS I got the error.
How could I solve this problem?
Thanks a lot.
Sara
mecej4
This issue is addressed in this sticky post. Other users have found a partial solution.
saradiruzza
Thanks so much. I installed oneAPI HPC Toolkit but nothing change; I get always the following message when I compile:
saradiruzza@MacBook-Pro-4 simulazioni % ifort threeBP_D.f90 routine_D.f90 -o threeBP_D
I hope to find a solution because otherwise I cannot continue to work.
Thanks a lot,
Sara
JohnNichols
Valued Contributor III
1. Buy a NUC - about 600 USD and it will run anything in Windows most people need.
just a thought, from someone who keeps a NUC handy for when everything else fails.
Although it cannot replace mother - yet.
