Switching from IVF 11.0.074 to 11.1.038 I get the following error message from the 64 bit (em64t) compiler (not the 32 bit) in debug and release mode:
ifort: error #10273: Fatal error in C:\PROGRA~2\Intel\Compiler\11.1\038\bin\intel64\fortcom, terminated by 0xc0000005
This comes from a F90 file that is big - 3.4 MB. I can send a project to you that will reproduce the error. With the necessary module files the the whole project will be in the order of 35 MB. Maybe a little less when compressed. Would that be possible?
I may be able to decrease the problem if a knew what the error number #10273 indicates. In a related thread you suggested a renaming of ifort_libFNP.dll to ifort_libFNPX.dll. I tried this, but no success.
How do we proceed? I've already reported this to Premier support.
Magne
Magne
If you've reported it to Intel Premier Support, then there's nothing you need to do here.
