ifort frontend bug
Eric_K_7
All,
The ifort (and presumably ifx) parser stumbles upon the identifier CLASSIFY in the following example:
module ifort_bug
type mytype
   integer:: value=1
contains
   procedure classify
end type mytype
contains
subroutine classify(t,iout)
class(mytype),intent(in):: t
integer,intent(out):: iout
iout=t%value
return
end subroutine classify
end module ifort_bug
Running version 2021.6.0  as ifort -c bug.f:
bug.f(5): error #5082: Syntax error, found 'IF' when expecting one of: , <END-OF-STATEMENT> ; =>
procedure classify
bug.f(5): error #8169: The specified interface is not declared. [CLASS]
procedure classify
bug.f(5): error #8169: The specified interface is not declared. [Y]
procedure classify
compilation aborted for bug.f (code 1)
Renaming to KLASSIFY avoids the error, but still, it's a bug.
--Eric
Shiquan_Su
The fix will be included in the next OneAPI release, which is typically within 3 months. Thank you.
Ron_Green
Hi Eric,
Yes, it's a bug in the fixed source form parsing.  I created your example as a fixed source form file 'repro.f'.
I discovered that if you rename this file from ".f" to ".f90" so the compiler treats it as a free source form there is no issue.
We have had a couple of such fixed source form parsing errors in the past year.  I'll write up a bug report.  Thanks for sending this to us.  My 2 samples attached.
Shiquan_Su
The test code provided by Ron has reproduced the desired bug. The bug has been reported to the proper channel to proceed further. We will keep posting updates here.
Shiquan_Su
