29416 Discussions
ifort -- passing array of unknown size (subroutine output) to another subroutine
Charles_L_
Hi all,
I'm new to Intel MKL. Here's a problem I've come across -- apparently a problem not related to MKL itself, but to the problem of how to declare and pass an array of hitherto unknown size as an output of a subroutine to another subroutine.
I'm trying to use mkl_ddnscsr to convert a matrix to its CSR format suitable for calling by Pardiso:
CALL mkl_ddnscsr(job,Nt,Nt,Adns,Nt,Acsr,ja,ia,info)
CALL PARDISO(pt,1,1,11,13,Nt,Acsr,ia,ja,perm,1,iparm,0,b,x,errr)
Problem is, I have no idea what the length of the CSR form Acsr and the index vector ja before calling the mkl_ddnscsr subroutine. How should one declare Acsr and ja in the main program, or the subroutine where these two lines are located?
I tried something like
INTERFACE
SUBROUTINE mkl_ddnscsr(job, m, n, Adns, lda, Acsr, ja, ia, info)
IMPLICIT NONE
INTEGER :: job(8)
INTEGER :: m, n, lda, info
INTEGER, ALLOCATABLE :: ja(:)
INTEGER :: ia(m+1)
REAL(KIND=8), ALLOCATABLE :: Acsr(:)
REAL(KIND=8) :: Adns(:)
END SUBROUTINE
END INTERFACE
and then
outside the INTERFACE, in the main program. But this configuration gives me the segmentation fault upon running.
On the other hand, if I try something like
INTERFACE
IMPLICIT NONE
INTEGER :: job(8)
INTEGER :: ja(:), ia(m+1)
REAL(KIND=8) :: Acsr(:), Adns(:)
END SUBROUTINE
END INTERFACE
and then
INTEGER, DIMENSION(:) :: ja
REAL(KIND=8), DIMENSION(:) :: Acsr
Then ifort would give me the following message:
error #6596: If a deferred-shape array is intended, then the ALLOCATABLE or POINTER attribute is missing; if an assumed-shape array is intended, the array must be a dummy argument.
Anyone got any idea how to work around this? What's the right way to declare ja and Acsr in the main program (or main subroutine) and pass them around? Thanks in advance.
