ifort read unformatted file?
laychao
I have a unformatted data which is write by gfortran (4.1.2). How can read the data using ifort compiler? which option should I use?
On what kind of system was this written? If it is a "little-endian" (x86 or x64) system, then you should not need anything special. If it is a "big-endian" system (SPARC, POWER, etc.), then use -convert big_endian
laychao
Thank you very much for the reply! I am very sorry for the vague description for the problem.
The data was written with the gfortran option "-frecord-marker= 8"(by default). I don't know how to make the option with ifort to recognize the data (record marker length is 8).
There is no option in Intel Fortran to support that mode. gfortran added that only to provide compatibility with g77 which always used 8-byte record lengths on a 64-bit platform. gfortran, some years ago, switched to the system Intel uses with 4-byte lengths for shorter records, expanding to 8-byte only when necessary.
laychao
Thank you very much for the reply! I have learned much from that.
