ifort version 11.1 bug?
Alex_H_5
Hi. I compile the following Fortran 90 code with ifort test.f90 -o test
program test
  implicit none
  real  ::  tc
  real  :: tau0
  real  :: theta,tau
  real  :: btau,neout
  real  :: fwhm
  real  :: zs
  integer :: model
  real  :: rcors,conc
  real  :: rs
  logical :: use_own_tau0,key
  use_own_tau0 = .false.
  theta = 85.1
  fwhm =      1.0
  conc =      2.2
  tc =   14.4
  model =      2
  rs = 0.8
  rcors =  0.04
  zs = 0.05
  key = .false.
  if(use_own_tau0)then
     call smooth_tau(theta,fwhm,conc,tc,btau,model,rs,rcors,zs,key,tau0)
  else
     call smooth_tau(theta,fwhm,conc,tc,btau,model,rs,rcors,zs,key)
  end if
  call tauprofile(tau,theta,tc,conc,model,rs,rcors,zs)
end program test
subroutine smooth_tau(theta,fwhm,conc,tc,btau,model,rs,rcors,r,key,tau0)
  implicit none
  real  :: theta,fwhm
  real ,optional :: tau0
  real  :: t,btau,z,sigma
  real  ::conc,tc
  integer :: i
  real  :: sum, delta,rcors
  real  :: rs,r,t1,t2
  integer :: model
  logical :: key
  write(*,*)theta,fwhm,conc,tc,model,rs,rcors,key,r,present(tau0)
  stop
  sigma = fwhm
  delta = sigma/4.0
  sum = 0.d0
  do i=1,24
       if(theta/sigma .gt. 3.d0)then
          t1 = theta + (i-13)*delta
          t2 = theta + (i-12)*delta
       else
          t1 = (i-1)*delta
          t2 = i*delta
       end if
     if(present(tau0))then
        sum = sum+(integrand(t1,sigma,conc,tc,tau0)+integrand(t2,sigma,conc,tc,tau0))*delta/2.d0
     else
        sum = sum+(integrand(t1,sigma,conc,tc)+integrand(t2,sigma,conc,tc))*delta/2.d0
     end if
  end do
contains
  function integrand(t,sigma,conc,tc,tau0)
    implicit none
    real  :: t,sigma,conc,tc
    real  :: integrand
    integrand = 0.d0
  end function integrand
end subroutine smooth_tau
subroutine tauprofile(tau,theta,tc,conc,model,rs,rcors,redshift)
  implicit none
  real :: tau,theta,tc,conc
  integer :: model
  real :: rs,rcors,redshift
end subroutine tauprofile
When I run the code, the following is output to the screen:
   85.10000       1.000000       2.200000       14.40000               2
  0.8000000      3.9999999E-02 F  5.0000001E-02 T
But since use_own_tau0 is false, the subroutine smooth_tau is called without the optional argument tau0, and so the value of present(tau0), which is the final thing written out, should be F. But as you can see, it is output as T.
I've confirmed that compiling with gfortran and running gives the correct result, that is, F.
Furthermore, deleting any of the seemingly extraneous lines of code following 'stop' seems to fix the problem, as does printing out fewer variables to the screen. Is this a bug with ifort, or is there some memory violation which I'm not seeing?
Alex
Lorri_M_Intel
Because subroutine smooth_tau has an optional argument, its interface needs to be visible within any routine that calls smooth_tau.
That's not true for your "program test".
Further reading:
Doctor Fortran and the Virtues of Omission
Doctor Fortran Gets Explicit - Again!
Also, if you compile with:
-warn interface
you will get diagnostics such as these:
U393563.f90(28): error #8055: The procedure has a dummy argument that has the ALLOCATABLE, ASYNCHRONOUS, OPTIONAL, POINTER, TARGET, VALUE or VOLATILE attribute.
 Required explicit interface is missing from original source.   [TAU0]
U393563.f90(30): error #8055: The procedure has a dummy argument that has the ALLOCATABLE, ASYNCHRONOUS, OPTIONAL, POINTER, TARGET, VALUE or VOLATILE attribute.
 Required explicit interface is missing from original source.   [SMOOTH_TAU]
Alex_H_5
Thankyou, that's very helpful!
