ifort
mike4239
Why the following option for ifort compiler does not add double under scores to the compiled function?
   /assume:2underscore
Ron_Green
Do not forget the documentation on 2underscores requires the name to have at least 1 underscore in the name.
"This option does not affect external names that do not contain an embedded underscore. By default, the compiler only appends one underscore to those names. For example, if you specify assume 2underscores for external names my_program and myprogrammy_program becomes my_program__, but myprogram becomes myprogram_."
what is the original name of the procedure or data?
mike4239
Thanks for your reply. Yes, the function name does contain a underscore.
Barbara_P_Intel
According to the DGR (Developer Guide and Reference), -assume:2underscore is only available for Linux and macOS. Looks like you are trying it on Windows; I see the "/".
mike4239
Thank you. Yes, I am using ifort on a Windows. I didn't know that this keyword is not applicable on Windows platform. Does that mean there is no way to add double underscores to function name on Windows?
jimdempseyatthecove
Use ATTRIBUTES ALIAS (intel.com)
Jim Dempsey
andrew_4619
r maybe this one:
!DIR$ ATTRIBUTES DECORATE :: exname
Steve_Lionel
No, DECORATE won't do this.
My question to @mike4239 is - why do you think you need to use this? The two-underscore thing was a quirk of the long-obsolete g77 compiler on Linux/UNIX systems. I can't imagine a circumstance where this would be useful on Windows.
That said if there is some non-Fortran routine you are trying to call and it somehow chooses to add two underscores to its name, you can specify any name you want with !DIR$ ATTRIBUTES ALIAS, or even the Fortran standard's C interoperabilty features.
mike4239
Yes, we do have some very old f77/g77 code. And, the code calls C functions (with underscore in their names).  The same codes are on Linux and Windows.
andrew_4619
I assumed (incorrectly it appears) that the only reason the underscores were being requested was to match the DECORATION of a calling convention. It appears from Steve's post that the request seems to match no known calling convention on Windows.......
Steve_Lionel
Right. The decoration conventions on 32-bit Windows are to prefix a global name with one underscore, and if the procedure uses the STDCALL calling mechanism, to append @n where n is the number of bytes pushed on the stack. 64-bit Windows uses neither of these. The DECORATE attribute is there so that you can have one ALIAS name and have the compiler apply the appropriate decoration based on 32/64 bit and STDCALL/C.
On UNIX and derivative systems, there is an informal convention that Fortran procedure global names have one underscore at the end. g77 did something weird and added two underscores if the name contained an underscore; modern Fortran compilers on UNIX/Linux systems don't do the two-underscore thig (but do use one trailing underscore for Fortran.)
