imsl compiller
bahadir_b_
ı am trying compiller imsl lib on visual studio but  get error
include 'link_fnl_static.h'
USE EVCRG_INT
USE EPIRG_INT
USE UMACH_INT
USE WRCRN_INT
IMPLICIT NONE
! Declare variables
INTEGER LDA, LDEVEC, N
PARAMETER (N=3, LDA=N, LDEVEC=N)
INTEGER NOUT
REAL PI
COMPLEX EVAL(N), EVEC(LDEVEC,N)
REAL A(LDA,N)
! Define values of A:
! A = ( 8.0 -1.0 -5.0 )
! ( -4.0 4.0 -2.0 )
! ( 18.0 -5.0 -7.0 )
DATA A/8.0, -4.0, 18.0, -1.0, 44.0, -5.0, -51.0, -2.0, -7.0/
! Find eigenvalues and vectors of A
CALL EVCRG (A, EVAL, EVEC)
! Compute performance index
PI = EPIRG(N,A,EVAL,EVEC)
! Print results
CALL UMACH (2, NOUT)
CALL WRCRN ('EVAL', EVAL, 1, N, 1)
CALL WRCRN ('EVEC', EVEC)
WRITE (NOUT,'(/,A,F6.3)') ' Performance index = ', PI
END
errors:
Error 16  fatal error LNK1123: failure during conversion to COFF: file invalid or corrupt LINK
Error 13  error LNK2005: __time32 already defined in LIBCMTD.lib(time.obj) msvcrt.lib(MSVCR100.dll)
Error 4  error LNK2005: __set_invalid_parameter_handler already defined in LIBCMTD.lib(invarg.obj) LIBCMT.lib(invarg.obj)
You're actually having link errors that seem at least partially due to having multiple versions of the Microsoft C++ libraries linked in. It also looks as if you've included in the link something that should not be there. Please attach a ZIP of the project after a failed build so we can see more context.
