install problem
zzdmy8
what is " secore.new: ChannelMessage.cpp:134: int CChannelMessage::Init(const CEasyString&): Assertion `configNode != __null' failed."meaning?,when i install fortran 10.1. thank you
Kevin_D_Intel
The error involves the installation licensing component (secore.new). The failure is due to an incompatibility between the level of gcc/cpp on the system and that used for secore.new.
What Linux distro and what version are you using?
What version of gcc is installed? (execute: gcc --version)
As a work-around try the following:
1. Ensure your most recent license file (.lic) is available on your system under /opt/intel/licenses (you may need to create this directory using the root account. Ensure the permissions are at least: 755)
2. Try installing using the following command:
./data/install_fc.sh --run
(Note: This command assumes your working directory is that where you expanded the compiler's tar.gz file)
zzdmy8
Fedora release 10 ,the version of gcc is Red Hat 4.3.2-7.
thank you very much! i will try
