29640 Discussions
intel compiler 11.074 double precision compilation error
Zuheyr_A_
I am using 64 bit compiler, version 11.0.074/bin/intel64/ifort with Fedora core linux.
I compile with double precision option r8:
ifort -O -save -r8 -o traf_ln_intel_64-r8.exe infnan.f90 traflib-zuheyr.f traf-zuheyr.f
There are misaligned common warnings but finally compilation crashes with the message:
/tmp/ifortKxAYXh.o: In function `ini_ax_':
traflib-zuheyr.f:(.text+0x343): relocation truncated to fit: R_X86_64_PC32 against symbol `block_' defined in COMMON section in /tmp/ifortKxAYXh.o
traflib-zuheyr.f:(.text+0x371): relocation truncated to fit: R_X86_64_PC32 against symbol `flow_' defined in COMMON section in /tmp/ifortKxAYXh.o
traflib-zuheyr.f:(.text+0x7f7): relocation truncated to fit: R_X86_64_32S against symbol `mesh_' defined in COMMON section in /tmp/ifortKxAYXh.o
traflib-zuheyr.f:(.text+0x806): relocation truncated to fit: R_X86_64_32S against symbol `mesh_' defined in COMMON section in /tmp/ifortKxAYXh.o
traflib-zuheyr.f:(.text+0x834): relocation truncated to fit: R_X86_64_32S against symbol `mesh_' defined in COMMON section in /tmp/ifortKxAYXh.o
traflib-zuheyr.f:(.text+0x849): relocation truncated to fit: R_X86_64_32S against symbol `mesh_' defined in COMMON section in /tmp/ifortKxAYXh.o
traflib-zuheyr.f:(.text+0x860): relocation truncated to fit: R_X86_64_32S against symbol `mesh_' defined in COMMON section in /tmp/ifortKxAYXh.o
traflib-zuheyr.f:(.text+0x874): relocation truncated to fit: R_X86_64_32S against symbol `mesh_' defined in COMMON section in /tmp/ifortKxAYXh.o
traflib-zuheyr.f:(.text+0x881): relocation truncated to fit: R_X86_64_32S against symbol `mesh_' defined in COMMON section in /tmp/ifortKxAYXh.o
traflib-zuheyr.f:(.text+0x8c0): relocation truncated to fit: R_X86_64_32S against symbol `mesh_' defined in COMMON section in /tmp/ifortKxAYXh.o
traflib-zuheyr.f:(.text+0x8ee): additional relocation overflows omitted from the output
I would greatly appreciate if you could help me please.
Many thanks and best regards,
Zuheyr
Zuheyr_A_
Zuheyr
Hello
I found my answer: I reduced the dimensions.
However, the misalignment of commons is still unclear to me. I looked at the User Manual on line and (admittedly quickly), I could not clearly see what one must do to prevent this...?
So I will still appreciate if I can get clear indications or reference for the solution of this problem.
Many thanks and best regards, Zuheyr
Zuheyr_A_
Zuheyr
Hello
rreis
