29276 Discussions
internal compiler error ifort vs ifx
ansayre
I am switching from ifort to ifx 2024.2.1.
I get a "xfortcom: Fatal: There has been an internal compiler error (C0000005)." when I compile the following with ifx, but not with ifort.
subroutine get_howoft()
implicit none
interface
function **bleep**(msg_)
structure /message/
integer(kind=4) :: level
end structure
! integer(kind=4), value, intent(in) :: asme_msg_
record /message/ :: msg_
real(kind=8) :: **bleep**
end function **bleep**
end interface
end
When I modify the source to remove the record/structure it compiles with ifx:
implicit none
interface
! structure /message/
! integer(kind=4) :: level
! end structure
integer(kind=4), value, intent(in) :: msg_
! record /message/ :: msg_
end interface
end
Unfortunately the subroutine compiles with ifx if the subroutine with the record/structure (needed for C interoperability) is moved to its own source file.
Are there any reported problems similar to this?
Alan
andrew_4619
implicit none
interface
        function bleep(msg_)
            structure /message/
        end structure
        real(kind=8) :: bleep
    end function bleep
end interface
end
Well that compile just fine in ifx 2025.0.0 I am not sure what your ** was about that won't compile but I assume your code does not have that.
But maybe standard Fortran rather than very old intel extensions would be better.
implicit none
interface
        type, bind(c) :: message
        end type
        type(message) :: msg_
    end function bleep
end interface
end
andrew_4619
implicit none
interface
            structure /message/
        end structure
    end function bleep
end interface
end
implicit none
interface
        end type
    end function bleep
end interface
end
ansayre
Andrew,
Thank you for having a look! The "**bleep**" was an automatic renaming of "**bleep**" where I renamed to obfuscate my source.
I am getting more ifx compiler errors that are unrelated to usage of records/structures. Looks like we are nearing the end of over 70 years Fortran usage.
Alan
andrew_4619
The compiler you are testing is already way out of date. Ifx is on a steep curve. You should use the latest.
