internal type constructor vs user-defined type constructor
Blane_J_
Hi, I‘ve encountered a derived-type constructor selection issue and the compiler reported an error which seemed non-relevant. The sample code is as follows:
module test
    implicit none
    private
    public :: var
    type :: tp
        private
        integer(8) :: var1
        logical    :: var2 = .false.
    end type tp
    interface tp
        module procedure :: init
    end interface tp
    interface
        module function init(var)
            type(tp)            :: init
            integer, intent(in) :: var
        end function init
    end interface
    integer(8), parameter :: default = 10
    type(tp),   parameter :: var     = tp(default, .false.)
end module test
The error message is:
error #6050: This parameter was defined too late.   [DEFAULT]
If tp and init interfaces are removed, the code can be compiled with no errors. Appreciate any help.
andrew_4619
The interface declares var as integer and not integer(8) but if that is the problem the message is strange!
Blane_J_
Thanks andrew. Unfortunately it's not the problem. As you suggested, I made some corrections to the sample.
And in addition, if the default value is set literally, it's all right.
module test
    implicit none
    private
    public :: var
    type :: tp
        private
        integer(8) :: var1
    end type tp
    interface tp
    end interface tp
    interface
            type(tp)               :: init
            integer(8), intent(in) :: var
        end function init
    end interface
    integer(8), parameter :: default = 10_8
    !type(tp),   parameter :: var     = tp(default, .false.) ! <--- Bad.
    type(tp),   parameter :: var     = tp(10_8,    .false.) ! <--- Good.
end module test
FortranFan
Looks like a compiler bug, deserving of submission at the Intel Online Service Center/
Steve_Lionel
I agree - the definition of the user constructor init is confusing the compiler. I don't see anything wrong with the code.
Blane_J_
Thanks FortranFan and Steve, I'll report it to OSC.
